Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
MAP Sensor Mounting Location with HSR
Old Mar 19, 2008 | 04:40 PM
Burnout91's Avatar
Car: '91 Z28 L98 G92
Engine: Modded L98
Transmission: Modded 700R4
Axle/Gears: Modded 10-Bolt
For people with Speed Density TPI, where did you locate / mount the MAP sensor when you converted to HSR? Thanks in advance.
Bill
Old Mar 19, 2008 | 05:32 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Re: MAP Sensor Mounting Location with HSR
Maybe drill and tap a hole for a male barbed fitting. Say 1/8" pipe. On my TPI I tee'd off one of the vacuum lines when I converted to speed density.
Old Mar 19, 2008 | 05:37 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
yep you can drill and tap a hole in the plenum somewhere. LT1 intakes have a hole in the top of the manifold, so you can copy that idea on the HSR
put it on the passenger side rear of the HSR plenum like factory TPI does it
There is a hole tapped under the plenum that could be used as well. Think its 1/8 NPT tapped, as i use it for my PCV valve vacuum setup. IF you run breathers or w/e, you probly could use that as a map sensor location as well.
either way you can get creative
Old Mar 20, 2008 | 08:38 AM
Burnout91's Avatar
Engine: Modded L98
OK, thanks for the replies. Anyone else?
Bill
9192camaro
16
Feb 3, 2019 12:21 AM
soarestransam
Aug 24, 2015 08:15 AM
91REDZ28VERT
Aug 18, 2015 10:16 PM
onebadazzsrt
Aug 15, 2015 07:00 AM
squiggy2
Aug 9, 2015 09:30 PM
