LT1 intake gasket
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
LT1 intake gasket
I measured my intake ports on my LT1 intake, then I measured the ports on my afr195's.
They are very close. I was going to use the FelPro 1205. The Afr's are about a 1/16" bigger than the LT1.
Would it help to gasket match that last 1/6th" ?
Is there any other intake gaskets that people used for their LT1 intake conversion on a sbc1?
Car: '91 GTA
Engine: 421sbc
Re: LT1 intake gasket
I searched this and the 2 gaskets were a fel-pro1205 and a intake gasket from a '72 camaro(John McMillan said this).
What did others use?
Did anyone have to port match?
Car: '91 GTA
Engine: 421sbc
I feel like I am talking to myself
I put the fel-pro 1205 gasket on my afr's and the lt1 intake. It works great on the heads but it is very close on the coolant ports on the intake. Too close that it might cause a coolant leak.
So I'm going to buy gasket paper and make my own. One side is 3" x 20" x 1/16"
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
I used a 1205 Fel-pro gasket and it is very close but does seal. I also looked at a MR Gasket intake gasket and it had more material to seal the water passages. I do not remember the part number.
Car: '91 GTA
Engine: 421sbc
This one?
http://store.summitracing.com/partde...G&autoview=sku
Also, I was reading the instructions on the afr's and this is the recomendation they said for the intake gasket
"Do not port match your manifold exactly to the gasket - leave 0.050 per side smaller."
Why do they say this??
Car: Red 87 Convertible Vette
Engine: 5.7 LT1/L98
Axle/Gears: 3.07
What did you end up doing here LB9GTA?
I'm running into the same issue and would love to know what you ended up doing.
Car: '91 GTA
Engine: 421sbc
I bought gasket paper and cut my own.
Actually, I cut 2 sets once I made the 1st one(just in case).
It's not that hard, just take your time and trace out the ports.
Engine: 5.7 LT1/L98
Axle/Gears: 3.07
Is it working for you without any problems?
This is what I will do if it doesn't seal the first time.
Thanks.
Thanks.
1992 Trans Am
May 10, 2023 07:19 PM
ambainb
Apr 25, 2016 09:21 PM
355tpipickup
Alternative Port EFI Intakes
Aug 29, 2015 10:47 PM
