Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
TPIS miniram HELP!!
Old Jul 10, 2008 | 12:32 AM
Cody Ashby's Avatar
Car: 1991 Firebird Formula
Engine: 6.0 LQ4
Transmission: TKO600
TPIS miniram HELP!!
Anyone on here that has the TPIS miniram intake please speak up..I need pictures of it to see how a few things work..Some of the sensors and stuff like that..Please just PM me or post pictures up here! Thanks alot guys
Old Jul 10, 2008 | 12:05 PM
CRUSHER's Avatar
Car: 88 Iroc
Engine: 350(300hp G.M crate, supercharged)
Re: TPIS miniram HELP!!
This may help, try these
http://www.eecis.udel.edu/~davis/z28...0218mrinstall/
http://www.tpis.com/instructions/Min...structions.doc
http://www.tpis.com/index.php?module...n_instructions
Old Jul 10, 2008 | 06:52 PM
Cody Ashby's Avatar
Engine: 6.0 LQ4
The very top link sort of helped..but thats what what im lookin for..is like pics and people that actually have one on there thirdgen camaro or firebird so i can talk to them about it
Old Jul 11, 2008 | 09:09 AM
CRUSHER's Avatar
Car: 88 Iroc
Old Jul 13, 2008 | 04:36 AM
HiTech5's Avatar
Car: 1986 Pontiac TA
Engine: 383
Axle/Gears: 3.70
Let me know what pics you need.
Old Jul 15, 2008 | 11:31 AM
Cody Ashby's Avatar
Engine: 6.0 LQ4
Hitech5, i basically need a bunch of pictures showing where the sensors are plugged in at..were and how stuff is ran to and from it..If you could just give me some close ups of both sides, and front and back.. Thanks alot!!
Old Jul 15, 2008 | 12:33 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I think you are in over your head. You need to sit down, take a deep breath, and learn about what all these sensors and things are your working with.
If you need pictures this tells me you don't understand how the things work and need some serious reading time.
-- Joe
Old Jul 16, 2008 | 08:41 PM
Cody Ashby's Avatar
Engine: 6.0 LQ4
not really anesthes..i have basically everything plugged in, i just want pictures to see if i forgot anything or did anything wrong...
Old Jul 16, 2008 | 08:48 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Well lets think about the basic systems here.
Brake booster
PVC
You have the Fuel pressure regulator that needs vac
You have your HVAC controls
Cruise control
Charcoal canister
Your EGR is now non functional, and you should fix that in the chip.
Is your car MAP or MAF?
I guess what i'm getting at is, everyones gonna have it different and have done a different setup. You need to know what is functional and not on your car, and where to put things.
-- Joe
Old Jul 24, 2008 | 02:36 PM
25thannivZ28's Avatar
Car: 1992 Z28 Camaro w/70k
Engine: 427 w/4" Mufflex Exhaust
Transmission: 700R4 3500 stall
Axle/Gears: 4.10:1
Sorry I can't give you pictures here, but I guess what i did was the following: Hope this helps!
I had to remove alot of vacuum lines & fittings from the original system & attach to the new. Brake Booster tube & PCV fittings on the driver side. MAP sensor & AFPR fittings on the passenger side. Coolant Temp switch & the antifreeze passage fitting on front. That was just about it, at this point I have gotten the intake on & new MSD ignition hooked up, now I just have to run the fuel lines & attach a pressure gauge on the shroeder valve. In addition to that, route all my vacuum lines accordingly to make it look nice.
The fitting that was originally beneath the TPI plenum needs to be removed & manually placed into the ductwork for safe operation. TPIS provided me a wire extension to extend from the sensor origination point (near the dist.) to the point in which you choose to mount it. Hope that helps ya!!
Old Jul 25, 2008 | 12:34 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
With a little extra finagulling (sp?) you can also run the entire wiring harness to the front of the engine and the injectors underneath the air gap on the MR...
Attached Thumbnails TPIS miniram HELP!!-img_0181a.jpg   TPIS miniram HELP!!-85319876i1legpnlimg_6102a.jpg
stalkier
Dec 6, 2015 11:25 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
Mutillator
Sep 17, 2015 04:38 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
