Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
how to check injectors on HSR
Old Jul 27, 2008 | 05:04 PM
age's Avatar
age
Car: 1992 Z28 1LE
hey guys,
I'm suspecting that I have a bad batch of fuel injectors on my HSR. I have fuel pressure at the schraeder valve. NOID LIGHT TESTS OK. Did a resistance check on the injectors, and found the resistance to be OK. But, I feel that the injectors just aren't firing.
The design of the HSR fuel rail doesn't really allow me to be able to pull the fuel rail upwards to physically be able to see the injectors firing. Is there any other way of doing this? thx
[edit] could I hook up 12V to each injector and check to see if the FP drops with the key in the "ON" position? Kinda like a jerry-rigged fuel injector pulser?
jklein337
Sep 19, 2018 06:23 PM
Brcharrelson
Aug 26, 2015 07:47 PM
ASE doc
Aug 25, 2015 09:14 AM
355tpipickup
Aug 22, 2015 06:06 PM
justin57
Aug 20, 2015 07:05 PM
