Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
mini ram question
Old Sep 13, 2008 | 03:28 PM
pearlphoenix's Avatar
Car: 86 Trans Am
Engine: 383
Transmission: Probuilt 700r4
Axle/Gears: 2.77 BW 9 Bolt
mini ram question
anyone know if you can run a large cap distributor with this?
Old Sep 16, 2008 | 05:47 AM
HiTech5's Avatar
Car: 1986 Pontiac TA
Engine: 383
Axle/Gears: 3.70
Re: mini ram question
I run a HEI distributor with internal coil. It is a little tight between the cap and the corner of the passenger side fuel rail. A little filing on the outside of the cap took care of it.
Old Sep 18, 2008 | 03:26 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
You probably will not be able to. Its very tight with the mini ram
Old Sep 18, 2008 | 04:07 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Yes, otherwise it would not work on corvettes.
See attached picture.
Old Sep 19, 2008 | 12:21 PM
APACHE JOHN's Avatar
Car: 1991 Z28
Engine: 350 TPI RAMJET COMING
I perfer the large cap HEI..........
Old Sep 19, 2008 | 12:31 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Why? It is less reliable than a small cap.
-- Joe
Old Sep 20, 2008 | 07:14 PM
jaykar's Avatar
Car: 87 Iroc Showcar - Saturday Nite Hun
Engine: 383 4-Bolt Truck Hyd Roller MiniRam
Transmission: B&M 700R4 - Edge 3200
Axle/Gears: BW 9 Bolt-TA Cover & Stud Kit - 3.2
Wider spark spacing especially when dealing with
higher volt setups at higher RPM.
Street setups, not worth the trouble. No gain.
Has been written about and documented.
I'd run one to with my MR but don't want to play
games to do it.
Later
Old Sep 20, 2008 | 09:08 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
On the large cap (electronic) the wider spark spacing means a voltage drop, especially with guys that run damn near 40 degrees advance. I don't see how that could ever be a good thing.
Not to mention the large cap HE coil has a higher dwell time than small cap, which makes it not helpful with higher revving engines.
-- Joe
Old Sep 21, 2008 | 05:12 PM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
Ok, so small cap = better? I am still trying to learn....
Old Sep 21, 2008 | 06:26 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
In my opinion.
-- Joe
Old Oct 10, 2008 | 09:01 PM
Fastbird's Avatar
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
There is nothing wrong with running a stock small cap distributor with high RPMs.
I have the miniram, small cap stock dist and turn 7500 through the traps. No break up, pulls hard.
Old Oct 10, 2008 | 09:24 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
7500?? solid roller?
Holy crap!
-- Joe
Old Oct 12, 2008 | 10:45 AM
Fastbird's Avatar
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
yeah solid roller 248/248 615/615 lift on a 110 lsa pulls hard in the top end.
miniram loves cams with same duration intake/exhaust. I may step up to a high 250 ish cam soon, but having a lot of fun with the 248 for now.
Old Oct 13, 2008 | 08:17 AM
HiTech5's Avatar
Engine: 383
Axle/Gears: 3.70
Fastbird - Last year I ran a single pattern solid roller 242/242 .603 lift on a 112lsa. The motor pulled hard and overall I thought ran well. No ET's though.
Over the winter I went with a dual pattern 4/7 swap with 238/244, .608/.615 on a 110lsa. I could not believe how much the personality of the motor changed with the dual pattern.
Overall, it out performs the single pattern at every rpm. Prior to installing this cam, I was 100% sure that the single pattern was best matched with my cylinder heads as the intake/exhaust ratio was high 70% to mid 80%.
Not trying to discount anything anyone said. Just my experience on my motor. All in all I think the MiniRam with a solid roller is absolutely killer!
Old Oct 14, 2008 | 09:38 AM
Fastbird's Avatar
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
Good info!
Do you have track times for the dual pattern cam? What made you decide to go with 4/7 swap?
I am shopping for a new cam and this is great info. What is the rest of your setup?
Old Oct 16, 2008 | 08:25 AM
HiTech5's Avatar
Engine: 383
Axle/Gears: 3.70
Fastbird - I do not have track times. I can tell you that my previous motor a 383 MR ran 11.61@118.
If sop means anything, the 406 and new cam feels like mid to low 11's. This is my opinion with no documentation.
I went with a 4/7 just based on some things I read and a local engine builder. I think the combo of the aggressive ramp and high lift makes this motor rev up like no other. I really like the tighter LSA of 110 instead of my old cams 112.
Old Oct 18, 2008 | 09:45 AM
Fastbird's Avatar
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
My cam is on a 110 also. I have semi-track times. I have a 700r4 in there now. I know better than to manually shift that kind of trans at high rpm so I just leave it in D and let it shift itself at 5000. I have 4.56 gears in the rear. That coupled with the low first gear of the 700r4 really make for some good short times.
Shifting at 5000 leaves a lot of the table when the cam makes power from 3500-7200. Even so, it ran 11.68 @ 116. I'll have the TH350 and 5000 stall in there for the first race of 2009. Also adding s-10 manual steering, electric water pump and ditching all the serp system. Hoping to pull off an 11.0.
Old Oct 20, 2008 | 05:52 AM
HiTech5's Avatar
Engine: 383
Axle/Gears: 3.70
Shifting at 5000 leaves a lot of the table when the cam makes power from 3500-7200. Even so, it ran 11.68 @ 116. I'll have the TH350 and 5000 stall in there for the first race of 2009. Also adding s-10 manual steering, electric water pump and ditching all the serp system. Hoping to pull off an 11.0.[/QUOTE]
I shift mine manually and I lock up the torque converter at 5500 in second gear. The motor takes on a whole new personality above 5000 rpm. I shift at 6600-6700.
Frozer!!!
Jan 19, 2024 04:55 PM
gixxer92
Sep 1, 2015 04:32 PM
ASE doc
Aug 25, 2015 09:14 AM
redmaroz
Aug 16, 2015 11:40 PM
L98GTA87
Aug 11, 2015 06:55 PM
