Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Anybody using a commander 950 and stealth ram combo?
Old Oct 16, 2008 | 06:19 PM
WIll36's Avatar
Car: 88IROC, 91Z28 + parts cars
Engine: 355, 408
Axle/Gears: 3.42 LS1, 9" w/ 4.56 and spool
I'm thinking about using the package deal from holley for the commander 950 and stealth ram intake on a 408 i'm in the process of building. The motor will have AFR 195cc eliminators, a custom hydrolic roller cam and shaft mounted rocker arms with about 600 lift at the valve, conservative duration in the mid 240s. Don't think it matters but i'm using a fully balanced forged rotating assembly from dart with SRP pistons. I want to run a stock hood and keep the drivability of EFI. Also projected horsepower is in the 520 range with a broad torque curve. I was planning on using the wideband version http://store.summitracing.com/partde...rsview=sku&Ns=
Anybody have any experience with this setup?
Old Oct 16, 2008 | 11:54 PM
iroc.86's Avatar
Car: 86 iroc
Engine: 383HSR
Transmission: custom 700r
Axle/Gears: moser 9" 3.90
Re: Anybody using a commander 950 and stealth ram combo?
i run this combo on my 383 with 190cc patriot aluminum heads works excellent!! it should support that hp w/ the 58mm throttle body and youll want like 40lbh injectors.
it also clears the stock hood! and the pcm is easy to tune
Old Oct 17, 2008 | 10:46 AM
WIll36's Avatar
Engine: 355, 408
[QUOTE=iroc.86;3919874]i run this combo on my 383 with 190cc patriot aluminum heads works excellent!!
What gasket do those heads take on the intake side. I know you can port the HSR out to a 1205 felpro which the AFRs I have use. I'm just wondering if you had to reradius the intake further up to compensate for that.
Old Oct 17, 2008 | 06:13 PM
iroc.86's Avatar
Car: 86 iroc
Engine: 383HSR
the patriots have a 1206 port and i did gasket match the intake and yes in my case it had enough material left to seal properly.
Linson
Oct 24, 2025 02:00 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
InfernalVortex
Apr 20, 2021 11:31 AM
ULTM8Z
Oct 2, 2015 01:25 PM
mfp189
Sep 27, 2015 09:25 AM
