Fuel pump for HSR...
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
If this is the wrong section...please move.
First off, I have a 383 Holley Stealthram built similiar to Orr's....
383, 11:1 compression, AFR 195 cc heads, ported HSR, custom cam 23x/24x at .56x lift on 111 lsa.
My question is...what fuel pump do I need to go with? I know Walbro has been having some trouble and was going to use one of those but now a little but scared. Nitrous will be installed at a later date but want to upgrade to enough fuel pump for future use...no more than a 150 shot. I've been using a stock AC Delco pump for right now and its been keeping up but I know I'm on a time table with it lasting.
Thanks guys for the help.
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
Re: Fuel pump for HSR...
It depends on your fuel needs. What injectors are you running? I am running a walbro 255 with my 427 ls1 and it keeps up just fine. I have heard about quality issues from some of the guys on here, but I guess I got lucky. Mine has been in for about a year, and no problems yet.
Car: 1988 Pontiac Firebird
Engine: 305 LT1 intake&heads
Transmission: TH700r4
Axle/Gears: 3.73 10bolt GM
i use similar setup and Walbro is doing the job, it is a bit noisy but you can get use to with it
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
Ok guys...thinking about the Walbro 255....any last thoughts....plan on ordering it tomorrow while the bed of the truck is off!
as long as You will keep half of the tank there will be no problem with Walbro, i use one, my friends put them on all race cars and they work just fine
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
what issues are there with the walbro 255lph pumps? i ordered one over a yr ago and i just intalled it but have yet to put the tank in... now im scared
the only issue with them is that they do not like to be semi submerged so You need to keep the tank always more than half-full, if You do a lot of cornering then even more, if this condition will be kept Walbro will do the job without any problem, oh and do not care when you'll hear noise from tank all the time, that's the way they work
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
The last time I checked the stock fuel lines are good for around 500 horse. I have never heard of the tank 1/2 full thing. I have run my tank down to the E several times for 5 years with a holley 255lph fuel pump and never had a problem. New to me
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
The problem I've been hearing with them is that they have been going bad after a few months. But Walbro has found the problem according to the Grand National site.
Car: 87 TA clone
when did they find the problem? and the 3/8" fuel line will support 500hp without a prob. its when u go to 1/2" that is needed for 1000hp or sumthing insane. thats what the HSR said in the instructions or something about how the fuel rails are 1/2" ID and they can support over 1000hp.
so take never below 1/2... hmm at 10mpg im gona be pulling over alot lol
can you tell me when did they found the problem and fixed it because as far as i know whis was/is the problem that 255 is high-pressure high-volume fuel pump and if she gets just a bit of air she starts to makes problem, i know that because i forgot to refuel yesterday and i had a problem running the car, but just after refulling problem just disappeared
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
Car: 87 TA clone
so it had nothing to do with the acutal pump working but just the bushing? thats ok to me... i spot tied it to the hardline/bracked in the tank anyway
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Sorry i never seen this thread til now. I have the Racetronix kit, using the Walbro GSS340M kit with the hotwire kit.
I never really run my car with much more than 3/8 tank. Keep the weight down. Never had any problems. I had my car at the track with the tank on E and still spraying it
never had a problem. Thats over 500whp. 10 seconds at over 127 mph. Now i bought this setup last summer i think it was. Not sure what else has changed since then but I'd go thru Racetronix if you havent already
My setup will be for sale since i will not need it. If you can wait i can pull it out for you. Not sure when that will be, probly over the next week if you want it soon but if not i wont be pulling it for alittle while
never had a problem. Thats over 500whp. 10 seconds at over 127 mph. Now i bought this setup last summer i think it was. Not sure what else has changed since then but I'd go thru Racetronix if you havent alreadyMy setup will be for sale since i will not need it. If you can wait i can pull it out for you. Not sure when that will be, probly over the next week if you want it soon but if not i wont be pulling it for alittle while
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
I saw where you are going turbo......what you doing with that nitrous system?
Car: 89 Iroc-z
Transmission: TH400
Nitrous is probly gonna go to LMSkyliner. He says he wants it but i'll ask him to see if he definately wants it or not. If your interested let me know you'll be next in line.
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
Yea...put me in line....just depends on when you sell it if I'll have the cash for it and how much you'll be asking for it.
Car: 89 Iroc-z
Transmission: TH400
I got it for a good price and i'll sell it for a good price. Let me see tho
Car: 87 TA clone
sooo when where the pumps defective? and when did they fix it?
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
Car: 89 Iroc-z
Transmission: TH400
Talk to racetronix if your interested in the Walbro pump stuff. They could tell you of any problems with those pumps. They are the most trusted vendor of those pumps that i know of. They are a sponsor on LS1tech. I've dealt with them for my pump and injectors and will continue to do business
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
