lt1 swapped tpi. check it out if you own one. pics inside
Car: 1989 Turbo Trans Am gta
Engine: 383 78mm turbo
Transmission: Th350 rmvb with brake
Axle/Gears: 9 bolt 3.45s
i have a sbc 350 w/ a lt1 intake. I did the conversion myself and all the machinening myself with the help of my dad. My car went 4 tenths faster in the 1/4 w/ just the intake upgrade, ive had some issues with it but i'm really happy with it. The only thing i hate are how all the houses and wires look in my bay.
I wanna see pictures of other sbc with lt1 intakes to see how you routed your stuff.
My car has had a lt1 intake for almost a year now, love it, but i'm tired of a messy bay soooo.....
i took the intake off, painted it, ported it, and i will figure out someway to make everything look stock, idk how tho, so please help me.
Last edited by noboostnogo; Jan 28, 2009 at 10:49 PM. Reason: Automerged Doublepost
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: lt1 swapped tpi. check it out if you own one. pics inside
Did you do that with the engine that it had from the tpi for i could do that and how hard was it
Car: 1983 G20 Chevy
Transmission: 4L60
Where did you source the slicone piece that adapts the throttle body to the 3" tubing?
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I thin kit's 4" to 3" or 4 1/2 to 3"..
I don't have a miniram anymore, this is what I'm running now:
Oddly enough, the same adapter works on the LS1 throttle body because the outside diameter is the same. (just not oval, but thankfully it flexes to whatever shape I need)
-- Joe
Car: 92 Camaro Z28
Engine: 383
Axle/Gears: 9"
WIRING LOOMS! If cleanliness is what you desire then wiring looms you must aquire! wires laid across valve covers and plenums? for shame! In looms they must go! mounted to firewalls and frames! Tidy it will be with wires out of sight. good day to you all and to all a good night.
Now that i look back at it it wasnt that hard of a conversion, cheap and fast. i might have spent close to 180ish.
LT1 intake+fuel rails -> free
lt1 AFPR-> 100
remote tstat-> 70
misc hardware (hoses, fittings)-> 20-30
machine job->free, my dad is a machinist and we have miling machines at home
Ebay
Last edited by noboostnogo; Jan 29, 2009 at 09:36 AM. Reason: Automerged Doublepost
Car: '82 Sport Coupe/'89 bird/'77 280z
Engine: 355/2.8/L28E(t)
Transmission: TH350/T5/4 spd
Axle/Gears: 3.73/3.42/3.54
Go get some split loom, the plastic tube that the stock harness is in. Clean the plug wires up with some acetone, or replace them. I think you can get some at radio shack if you want new stuff, or the junkyard for way cheaper used stuff.
I KNOW I'M NOT THE ONLY ONE ON HERE WITH THE LT1 INTAKE, SO POST UP YOUR PICTURES. i would like to see them
LOL
it is not a real lt1. It used to be a tpi, but it has a modified lt1 intake, it has a distributor hole, and modified hole pattern, and water port. it is something pretty straight forward, check out www.lt1intake.com for more info. it is very simple to do if you have access to the right tools.
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Could you still read codes like that because i want to do that with my dads camaro he likes to go fast
finished product. im really happy with how good it turned out. pictures dont do justice.
I have to take better pics, but you get the idea.
I wanna see pictures of other lt1 intakes on sbc.
^^^ nice, did you mod it yourself? how long did you have the lt1 intake on there? any problems with it?
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
The only thing I don't like about this swap is the thermostat issue, other than that if I had TPI it would be this or a multiport setup. Good job!
I bought it pre-modded from a board member for about $300 everything included
The intake holes were slightly off but nothing I couldnt handle
Its been on the racecar for about a year now, no issues
Whats everyones gripe with the remote thermo? Its extremely handy
You can literally mount it ANYWHERE
I had it in the initial position you see because I was too lazy to get more tubing and just used a few bits of original heater hose. A few weeks later I got longer hoses and mounted it on the framerail
The current project needs that area so Im moving it again to the cyl head
Id like to see you move a fixed thermo around like that
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
can sum one post a link to an Ebay page that sells the silicone boot that goes from the TPI to the 3" tubing! if u do im gona buy it now! i need one!
Car: 1987 Z28
Engine: LG4
thats if your running MAP 91-92
:EDIT: im looking for someone to do a lt1 intake conversion relatively cheaply. i want to do it the right way and not have a hack like last one i bought from someone.
Car: 87 TA clone
is that the rite size? 4" to 3"??? to fit the TB? i have a 58mm TB will that work noboostnogo? are the grannelli high flow mafs the same outer DIA as stock?
toyota h8r... nope i got a MAF car.... now goin with a 383 HSR with 58mm TB and grannelli MAF... and im making a new ram air straight into the plenum from my ram air II hood
the one i made for my TPI wont work cuz the HSR is taller.
the one i made for my TPI wont work cuz the HSR is taller. Senior Member
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
^^yeah something like that
the one i made for my TPI wont work cuz the HSR is taller. Thread Starter
wow this is old. I dont have fuel injection anymore, i decided to go with a carb now and got rid of everything under my hood, no wiring is shown now. Its immaculate. ha i will post pics when i get a chance.
ok so heres a lil something. As you can see i still have alot to do but the weather is not helping, it was raining when i took the pix. I still gotta hook up the fuel lines, throttle cable and a few more wires. Def. getting rid of that air cleaner and going with something better
The engine bay is flat black so everything stands out, i ordered a blue throttle cable bracket like two weeks ago but apparently it was on backorder so i'm exchanging it for a red one tom. I also ordered the heater box without AC and i should get it tomorrow. My goal is to finish it tomorrow or at least get it started since i dont have to work or have no classes. We'll see
Car: 1991 Trans Am
Those of you that have bought an intake already machined, where are you getting them? I've got an intake I can send out that's ready for conversion, just gotta find someone to do it.
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Would these be california smog legal by any chance? How hard is it to get them to work?
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Since the OP removed the LT1 intake in favor of a carb intake, I'm locking this thread. I imagine from now on updates will be posted in the carb board.
-- Joe
-- Joe
1992 Trans Am
Aug 8, 2015 08:16 PM
rsrmoore
Aug 7, 2015 08:44 PM
