Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Ford SVO 30LB injectors
Old Feb 28, 2009 | 01:39 AM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
I need the part # for ford 30LB bosch style injectors..thanks
Old Feb 28, 2009 | 08:11 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Re: Ford SVO 30LB injectors
I just bought a new set. The new Ford 30#/hr injectors are part #:M-9593-BB302. Yes, two Bs, thats important. I believe that these are the new Bosch III design. These fuel injectors cost me $289 and they came flow tested and are a matched set. I purchased them from Fuel Injector Connection in Georgia.
Old Mar 1, 2009 | 10:45 AM
Car: 89 Formula 350
ok cool I saw those in Summit but the part # was messing me up because of the extra B. They also looked physically different from the original Bosch style injectors, but if you say they are just an updated version cool I'll get them
Old Mar 1, 2009 | 11:49 AM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
The double B indicates the new Bosch injector. Call John at Fuel Injector Connection, he is very informative.
Old Mar 1, 2009 | 11:50 AM
RedHawkLB9's Avatar
Car: 89 Formy
Engine: carbed 355ci
Transmission: A4
Axle/Gears: 3.73 10 Bolt
not to thread jack or anything..but you can use ford injectors on our gm cars?
Old Mar 1, 2009 | 01:18 PM
Car: 89 Formula 350
yes
Old Mar 11, 2009 | 09:10 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Yes, just buy the EV1 style. I think that the EV1 indicates the type of connector. Ford also makes the EV6 style fuel injectors.
Old Mar 16, 2009 | 12:12 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Are they modified or untouched?
-- Joe
Old Mar 16, 2009 | 10:30 PM
irocuroc's Avatar
Car: 89 iroc
Engine: l98
Transmission: tremec
-- Joe
i bought some too they are brand new in the ford racing box. They were matched up. better price than jegs. Jons a good guy. Heres what I bought
http://fuelinjectorconnection.com/sh...od&productId=5
Old Mar 17, 2009 | 10:20 AM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
It is my understanding that these injectors are brand new and flow tested by John at Fuel Injector Connection. The injectors were shipped to me with the flow sheet included in the bax. John marked two of the injectors that he thought should be put in #7 and #8.
I have completed my HSR install using these injectors. The engine is running great, now that I found out that the MAF was bad.
Old Mar 23, 2009 | 03:00 PM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
got my brand new EV1 style SVO 30lb bosh injectors(AKA red tops) for 200 shipped. cant beat that.
it was from a ford racing parts dealer in NJ... cheapest ive ever seen.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Veaceonee
Sep 29, 2016 08:15 PM
92-Formula
Dec 12, 2015 10:34 PM
webeeZ28
Sep 14, 2015 12:00 PM
