Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
TPI 305 out HSR 383 in, What wires do I keep?
Old Mar 14, 2009 | 07:43 PM
jlanham's Avatar
Car: 1987 IROC Z28 1le brakes
Engine: switching to 383
Transmission: installing tko 600
So just wires hanging in the engine bay now (ok some other stuff but the engine is out!) Here is my question. I have the complete HSR kit with Holley's comander 950 and their wiring harness. Do I want to remove the entire TPI harness? or is there something I need to keep from the TPI system? I have no smog laws here in my state with the exception of 2 towns, which I am exempt in based on age in a year and a half, so I don't need that stuff. I plan on pulling the air conditioning out and don't really care to keep cruise control ect. Can I just pull all of it out?
I would really like to clean that engine bay out and make it less cluttered. Just worried I am going to take to much out. Any suggestions?
Old Mar 18, 2009 | 04:56 AM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
Re: TPI 305 out HSR 383 in, What wires do I keep?
the commander has its own wiring and computer correct id so you can remover the whole tpi and computer and just replace it with what you have just unplugg everything don't cut incase you need to reuse anything
Old Mar 21, 2009 | 06:47 PM
pondriver's Avatar
Car: 1992 Camaro ZO3
Engine: 350 HSR
Axle/Gears: 9 bolt/3.70's
When I removed my ecm and wiring. I did have to cut some wires. But, I kept my AC. Ijust putchased the HSR with the commander. It has all you will need except for the torque converter lock up, if it's an auto.
Old Mar 22, 2009 | 01:42 PM
tom86iroc's Avatar
Car: 1986 iroc
what wires did ya cut?? jegs makes a switch now u use for the lock up function
Old Mar 22, 2009 | 02:06 PM
pondriver's Avatar
Engine: 350 HSR
The signal wire from the A.C. to the ECM for example. It's been a while but since I removed it but, you can't just pull one harness out without it being connected to another. On my 92 anyway. There were a few grounds and stuff I had to cut and solder. My t/c locks up hydraulically now. I was just letting the guy know that the 950 commander has no provision for t/c lockup.
Old Mar 23, 2009 | 04:27 AM
tom86iroc's Avatar
Car: 1986 iroc
hey no problem thanks for the info i have a stick so i didn't know that
Fast355
Dec 2, 2016 06:33 PM
ASE doc
Aug 25, 2015 09:14 AM
85Iroc-Z
Aug 13, 2015 01:58 AM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 10, 2015 07:44 AM
