Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Big cap to small cap hei for stealthram.
Old Apr 9, 2009 | 09:10 PM
jeaux's Avatar
Car: 85 Camaro Z28
I have searched, and havent found anything specific telling me whats involved. The car is an 85 z28 tpi w/ coil in cap, I would like to change the distributor to a later 87-92 style remote coil for use with the stealthram, or should i look to the aftermarket. Any help? Thank You.
Old Apr 9, 2009 | 09:27 PM
86White_T/A305's Avatar
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
Re: Big cap to small cap hei for stealthram.
I believe you can swtich to small cap hei if you buy a stock replacement for a 87+ tpib..and tbi i think is the same.I know there are adapter plugs to convert the wires going to the cap but not sure if it works for the esc module on the small cap.I think aftermarket might be an easier swap for you like msd..they have specific diagrams of the wires plugs that might help you.
Wish I had more answers for ya but I hope that helps get you a start.
Old Apr 10, 2009 | 10:43 AM
84KYSS's Avatar
Car: 84 Monte Carlo SS
Engine: 408
Transmission: 700-r4
The swap is simple. I used a brand new small cap I bought off E-bay for about $50. If you search for JP86SS he has a wiring diagram on his site. I believe you need 12+V switched power and one other wire. No wire adapters needed as long as you don't mind splicing, soldering, and heat shrinking the wires.
Old Apr 11, 2009 | 09:22 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by 86White_T/A305
.I know there are adapter plugs to convert the wires going to the cap .
If you have the std electronic HEI dist with four wire connector you can get a large cap to small cap conversion harness here $15
http://www.eficonnection.com/eficonn..._pigtails.aspx
Mike can also do you the small cap dist 2 pin coil plug with a long pigtail to hook up the remote coil
As stated above use any F-body small cap dist and remote coil.
Pink 12V wire from HEI cap goes to coil +
White tacho wire goes to coil -
Pink and white on new pigtail go from coil to new dist
Adapter harness takes care of the ECM advance control side of things
Old Apr 11, 2009 | 10:51 PM
jeaux's Avatar
Car: 85 Camaro Z28
Thank Y'all for the replys. I haven't been in a third gen since 03, I'm just glad I got another 1. Let the modding begin.
Old Apr 13, 2009 | 09:38 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Couldn't believe I actually found the thread.
Search does work after all
https://www.thirdgen.org/forums/alte...r-wireing.html
junkcltr
Aug 2, 2019 11:12 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
gixxer92
Sep 1, 2015 04:32 PM
kah992
Aug 19, 2015 02:55 PM
