Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Good intake manifold??
Old Apr 12, 2009 | 08:51 PM
SSZ2891's Avatar
got a 89 305 tpi and wandering if an upgraded intake manifold would give me any performance benefits and if so how much am i looking at. what is a good manifold and whatis the easiest one to replace????
Old Apr 12, 2009 | 08:58 PM
J91's Avatar
J91
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
Re: Good intake manifold??
Change your runners before anything, SLP or Holley make good intake kits for our cars. I'm sure someone on here has other suggestions, do a search for threads on this topic, you'll learn alot...
Try Edelbrock they have a runner and manifold setup. If you do these mods you should upgrade to K&N air filters and exhaust, especially some headers, the stock manifolds are very restrictive. Exhaust mods will help take advantage of the intake mods......
Old Apr 13, 2009 | 07:26 PM
SSZ2891's Avatar
what headers would you suggest are good plus are easiest to install
Old Apr 13, 2009 | 08:45 PM
J91's Avatar
J91
You'll need headers and y-pipe to your cat, Hedman, Edelbrock, hooker, they are all good, I have Hegman TTY coated, whatever you can afford...
Old Apr 14, 2009 | 12:33 PM
J91's Avatar
J91
I have K&N lifetime airfilters w/10K mi on them and an airfoil for a TPI throttle body if you need $25 for ea or $40 for all... PM me if interested. Problem w/TPI is the runners and intake do not breathe well, if you modify the intake to take advantage, you should upgrade the exhaust, if you can't afford it all, you can do it one piece at a time.
Old Apr 14, 2009 | 09:11 PM
SSZ2891's Avatar
im already running k&n's but what exactly is the air foil and what will it do for me?
Old Apr 14, 2009 | 09:24 PM
J91's Avatar
J91
It smooths out airflow into the throttlebody, angled/Curved piece seperates the two barrels on the throttle body, Jegs sell 'em, Summit, etc. Cuts down the turbulence in the air coming in , allowing better flow.
The Holley piece is $60 @ Jegs part #510-120-140 for TPI and LT1. Aftermarket throttle bodies have it molded in the front, this piece bolts right in. The one I have is a Holley...
Old Apr 14, 2009 | 09:47 PM
SSZ2891's Avatar
Any hp gains?
Old Apr 15, 2009 | 05:36 AM
J91's Avatar
J91
Minimal, advertised as 10-12, more like 2-3, however, smoother more tractable power throughout the entire rpm range, more consistency and efficient use of what you already have. Better mileage also... Works well w/ increased airflow of K&N filters....
Old Apr 24, 2009 | 08:52 PM
SSZ2891's Avatar
what intake manifold should i look for. its tpi not carbureted does that matter which intake manifold can i replace with the stock one without doing any major work to make it fit?
Old Apr 24, 2009 | 09:39 PM
J91's Avatar
J91
Holley stealth ram is supposed to be good??
Jake_92RS
Jan 28, 2020 10:37 PM
transaero
Aug 31, 2015 01:14 AM
86IROC112
Aug 17, 2015 02:00 PM
st.evel07
Aug 13, 2015 06:15 PM
Jake_92RS
Aug 11, 2015 10:39 AM
