Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
TBI computer with HSR?
Old May 3, 2009 | 02:52 PM
lancerracer's Avatar
Car: 1988 T/A WS6
Engine: none right now
I am currently rebuilding my 88 T/A with TBI. Will I need a wiring harness out of a TPI car or can I somehow use my TBI harness? Thanks!
Old May 3, 2009 | 04:46 PM
scamaro355's Avatar
Car: 92 rs
Engine: 355 stealth ram, dart heads, S480
Transmission: 4L80E
Re: TBI computer with HSR?
i was in hte same situation.. i swapped from a tbi to stealth ram, did alot of research and yeah it can be done. But in the long run its easier to get a harness from a 90-92 tpi....i picked mine up for 100.00. Im curious are you doing an entire build on a 350 or are you gonna try to use this on the stock 305?
Old May 3, 2009 | 05:32 PM
Car: 1988 T/A WS6
Since the car is going to be off the road for a while, I am planning on building a 350. If I needed to drive the car, I probably would try to work something out with the 305, but since its not I am going to go the 350 route.
Old May 3, 2009 | 06:28 PM
scamaro355's Avatar
Car: 92 rs
Transmission: 4L80E
good deal...because thats alot of intake for a 305, I love spinning mine up past 7 grand and hitting 2nd...that intake and a good set of heads...makes these cars a blast to drive
Bubbajones_ya
Jul 6, 2024 08:32 PM
92firebirdguy
Sep 1, 2016 07:53 AM
Glowsock
Sep 11, 2015 11:09 PM
92rsvortec350
Sep 10, 2015 10:54 AM
Wylecoyote08
Sep 8, 2015 08:26 AM
