Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
HSR guys inside please
Old Mar 28, 2010 | 09:33 AM
joe2844's Avatar
Car: 1991 Camaro Z28
Engine: Carb 5.3
Transmission: Th350
Axle/Gears: Moser 12 bolt, 4.11 gears
hey guys i ordered a HSR and am awaiting its arrival. holley says to use felpro #1205 intake gaskets. this is going on a stock headed L98 from a 88 iroc. i lined the gaskets up to the heads and noticed that the gaskets are slightly larger than the ports on the heads. will this create turbulence and hurt power? should i port match the heads to the gaskets? if the heads were off the car i would just go ahead and do it but they are still installed. guess what im asking is is it worth pullin the heads off to do this or are performance gains/loss negligable?
Old Apr 24, 2010 | 12:52 PM
rhuarc31's Avatar
Car: 89 Formula 350
Engine: 409 nitrous' small block
Re: HSR guys inside please
Umm, unless you are a great head porter the HSR will way outflow the heads no matter what. Port matching actually gives you the smallest gains of any porting. It's so common because its so easy LOL. Tho I would say that fresh head gaskets never hurt anything if you've already got the motor that far apart anyway.
Old May 6, 2010 | 02:30 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
I ran my HSR on the stock heads without problems that I could tell. Ran great with HSR. Was running lean on the stock tune and abit with my modified timing table tune but ran strong. A step in the intake tract is never a great thing but if you port matched and didnt open up the whole port in the head, there would be no gain anyway.
Old May 6, 2010 | 02:41 PM
91interceptorZ's Avatar
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
agree with both above...I ran mine on stock heads for a bit. No issues, there will be some overlap, the hsr will also have slightly bigger ports than the heads, but unless you port match, don't worry about it.
Old May 6, 2010 | 06:54 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
I also had no problems with the HSR, 1205 gasket an stock heads on my old engine.
ASE doc
Aug 25, 2015 09:14 AM
Thirdgen89GTA
Aug 20, 2015 12:11 PM
355tpipickup
Aug 19, 2015 10:02 PM
Street Lethal
Aug 14, 2015 08:25 PM
355tpipickup
Aug 13, 2015 07:35 AM
