Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
small cap distributor for hsr swap
Old May 3, 2010 | 03:56 PM
Billd's Avatar
i have an 86 camaro with the large coil in cap distributor from what i understand i need the small cap distributor to go with the hsr intake... The person that owned the car before me wallowed out the holes for the dist cap and really messed up the housing and the gear is about all chewed up so kinda planned on a new dist. anyway. my question is what all do i need to convert to the small cap remote coil distributor and what wiring will need to be changed...
Old May 3, 2010 | 07:14 PM
slrvette's Avatar
Car: Corvette
Engine: 388 HSR custom Cam see sig
Axle/Gears: D44 3:45
Re: small cap distributor for hsr swap
When I converted mine I used a Cardone from Advance Auto Parts. Its from a 92 camaro
Old May 3, 2010 | 08:04 PM
2bfeard's Avatar
Car: 1986 iroc
Engine: 350 .060 AFR HSR XFI280
Transmission: transgo 700r4
I went to my local wreakage yard cut off the later style dist connector and coil wires, then cut off the old dist connector and used butt connectors to crimp it together, wires are even the same colors, its the cheapest/easiest way to go i didnt pay nothing for the connectors
Old May 3, 2010 | 09:02 PM
RedGut86's Avatar
Car: 86 Corvette 383
Engine: 383 LPE build
Transmission: 4+3... T56 soon enough
Axle/Gears: 3.07
You can get a nice set of connectors and not hack up the factory stuff from Jim's Performance. Just give him a call and he'll know what to send you. Bought mine a few years ago but I want to say... ~24$
jimsperformance.com
Old May 4, 2010 | 08:51 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
3rd Gen member and supporter S10Wildside
(Mike @ EFI Connection ) has the large to small cap adapter harness for $20
Excellent service
http://www.eficonnection.com/eficonn..._pigtails.aspx
Old Jun 2, 2010 | 09:10 PM
shankymank78's Avatar
Car: 1991 1LE 350
Engine: 383 12.1 comp afr 195, hsr,
Transmission: 700r4 by probuilt automatics
Axle/Gears: 1o bolt 3.55 motive gears
Excellent service
The small cap distributor will work but you will find that it is a very tight fit as it will
Touch the back of the intake and limit how much u can turn it to adjust the timing.
I am still using it but will replace it soon as I get some more time to enjoy the car and feel like re wiring the ignition not something I'm looking forward to
Old Jun 2, 2010 | 09:26 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
You mean the HEI is a tight fit ?
Small cap dist has plenty of room which is why guys use it in HSR swaps
Old Jun 2, 2010 | 09:36 PM
cIaRmOaCrZo's Avatar
Car: 86' IROC-Z....and 5 other 3rdgens
Engine: 383 hsr
Transmission: built 700r4
Axle/Gears: stock 3.23, 10bolt
yeah i just went to the junkyard and snipped off the connectors too lol. its very easy. like he said, they are all the same colors as the large cap dizzy's. its a total of 6 wires. if you can swap out a radio...then you can do this lol
Old Jun 2, 2010 | 09:40 PM
Car: 1991 1LE 350
It is an hei cap but it has an externally mounted coil. They came stock on late model camaros and firebirds. Much smaller then the older HEI caps.
Old Jun 2, 2010 | 10:14 PM
Car: 1991 1LE 350
I love the car. It looks sweet. I have a 91 z28 1LE 350. I have stroked the motor out to 383
Forged rotating assembly with 11 to 1 compression, hsr intake holley fuel rail 36 lbs inj, AFR
195 heads, bbk 58mm throttle body custom ecu by arizona tpi, headman elite headers custom exhaust, built 700r4 soon to be replaced with a t56,3.73 detroit locker, and much more.
Old Jun 4, 2010 | 03:20 PM
Engine: 383 hsr
wow, that sounds like a pretty sweet setup. kinda like mine, but on steriods lol.
Old Jun 4, 2010 | 04:41 PM
Car: 1991 1LE 350
Thanks ill post some pictures when I figure out how.
Old Jun 11, 2010 | 02:51 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
wait, you went from HEI to a TBI style distrib?
how?
i want to go from a TBI small distrib to a big HEI one
but i dont see any way to do it easily unless someone knows something?
thanks
Old Jun 11, 2010 | 02:53 AM
RedGut86's Avatar
Axle/Gears: 3.07
Why? That whole spark jumping thing is bogus at street RPMs.
1992 Trans Am
May 10, 2023 07:19 PM
junkcltr
Aug 2, 2019 11:12 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
86White_T/A305
Aug 17, 2015 12:16 AM
cstrobel65
Aug 15, 2015 10:19 AM
