Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Just installed stealth ram
Old Jun 12, 2010 | 05:24 PM
Nater36's Avatar
Car: 1989 Firebird Formula
Engine: 310 HSR, TFS heads, zz4 cam
Axle/Gears: 9 bolt 3:70
Hey everyone, I just want to let everyone know my personal experience with the stealth ram..
Installation was easy other than the 1000 miscelaneous parts i had to purchase here and there. I have a 305 .030 over (310), zz4 cam, roller tip rockers, hooker headers, 3" exhaust ypipe and all, spiral flow muffler 4in/out adapted, !cats, !ac, !smog. T5 tranny, 3:70 9 bolt... Along with the stealth ram i added 22lb injectors and i have not yet changed that in the chip. Timing is about 9 or 10 btdc(timing light broke around there). I am currently using the non adjustable fuel pressure regulator which holley claims to be 43psi.
I can tell you this much as for the "major torque loss myth", I can barely tell a loss, BARELY. The tires still light up vigorously with a 2000 rpm punch.
However anything i lost down low is more than made up for in the top end. The engine no longer loses steam after 5k rpms. It delivers a smooth consistent pull all the way to 5700rpm (where i previously set my rev limiter). I know it will pull much past but im not risking my bottom end.
I am more than satisfied even counting all of the extra parts and time i had to spend to get it all together. I HIGHLY recommend this intake to anyone with a 305.
I have all tuning equipment and wideband o2. I am just waiting to get an o2 bung welded in so i can begin tuning.
Old Jun 13, 2010 | 08:52 AM
Sprayed92's Avatar
Car: 92 Formula
Engine: 383 248/256 cam
Transmission: 700r4 3500 stall
Axle/Gears: 9" 3.89 gears detroit locker
Re: Just installed stealth ram
you know i said the same thing to a couple of guys when i did the swap on my 350 motor but then again i already had a 2800 stall at that point too haha
Old Jun 17, 2010 | 12:00 PM
91350rs's Avatar
Car: 91 camaro RS
Engine: superchargered 350
Transmission: t56
Axle/Gears: 4.10
with my tpi i could break 2nd loose but it would catch quickly, after i put on my stealth i can break 3rd loose
Old Jul 2, 2010 | 02:27 PM
Abubaca's Avatar
Well, the torque loss isn't a myth, it's physics. It's the ole thumb over the hose analogy. But it's not like it's always a bad thing, and it's not like the HSR is the only intake suffer torque loss. And honestly it's not really that it has LESS torque, it's more that the TPI has MORE torque. (on average). The debate comes into play when you trade RPM's down low for RPM's up high, but yet never actually USE those upper range RPM's unless you're racing, where as you ALWAYS use those lower RPM's in everyday driving.
It's matter of driving style, intended use, and personal preference. No right or wrong answer. I think the HSR is a great intake, and if I didn't LOVE the appearance of the stock TPI, I'd run an HSR myself.
Glad you like it!!!!!!!!
Old Jul 3, 2010 | 10:41 AM
86White_T/A305's Avatar
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
I love the look of my polished tpi when I had it.. and the insane low end torque grunt but ..that grunt always ended so fast and left me wanting more..mashing down on the gas pedal lol.I didnt feel like going to great lengths to hog the tpi out to extremely flow uptop either and for the price of the hsr used I cant beat the performance potential it created without even being ported yet.
Now that my torque is a more flat curve and upper rpm hp is upto the task..I might not have as much of a snap off the line but knowing that the car is flying and still peeling rubber is great.Even cruising on the highway..I glance down and dont relaise how fast im going
Old Jul 13, 2010 | 12:44 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Thats the thing about TPI, its a peaky torque curve. below 2800 or so it makes so-so torque and above 3600 its torque starts falling off alot. Between 2800-3400 it makes a good deal of torque.
HSR gets the advantage by gaining torque below 2800, losing peak torque in the 2800-3400 range, but gaining more again after 3600. Its a flatter curve for more acceleration over the entire rpm range.
Glad to hear its working fine on a 305 with zz4 cam. Thats a nice setup. Cant wait to see how it runs once all tuned. I want to start a 305 build for a fun driver. Just something to toy with and then sell off.
Old Jul 13, 2010 | 01:43 PM
Nater36's Avatar
tell ya what, ill trade you my 305 for your 401. and ill even throw in a full tank of gas
im actually ordering some of those 305 tfs heads here soon, probably friday i beleive.
9192camaro
16
Feb 3, 2019 12:21 AM
ASE doc
Aug 25, 2015 09:14 AM
L98GTA87
Aug 11, 2015 06:55 PM
bryan623
Aug 10, 2015 11:33 AM
