Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Tbi to HSR
Old Jun 28, 2010 | 04:06 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Tbi to HSR
Hi I am interested in switching to hsr once I drop in my 350 in my rs but since I have tbi i am not sure exactly what parts I would need. Has anybody ever done this swap from tbi to hsr or can someone tell me the parts I will need to do this I would like to be buying the parts little by little since I ain't over $1000 to spend at once. I would really appreciate any hints.
Old Jun 28, 2010 | 04:34 PM
Ronny's Avatar
Re: Tbi to HSR
You will need a different ECU/prom as well.
Old Jun 28, 2010 | 04:49 PM
Ronny's Avatar
Re: Tbi to HSR
What lead you to the HSR as the best choice?
Reason I ask is that some owners of TPI cars that wish to upgrade manifold due to engine mods(heads/cam) find HSR as a good alternative. However you are TBI so cost wise and performance wise there are other maybe better options available to you.
Old Jun 28, 2010 | 05:32 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: Tbi to HSR
Well I wanted to swap to tpi but since I have researched that to have a good tpi hp you need aftermarket runners and alot of porting which I think would be kinda more pricey also since I am gonna swap a L98 block with a aftermarket cam I would really like to take the advantages of the power curve at the high rpms. I hope this makes sence a bit.
Old Jun 29, 2010 | 08:21 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Tbi to HSR
All up above in the stickies
https://www.thirdgen.org/forums/alte...gal-whats.html
https://www.thirdgen.org/forums/alte...r-install.html
Old Jun 29, 2010 | 09:20 AM
Ronny's Avatar
Re: Tbi to HSR
Most of us TBI owners want to get by low cost. Best bang for buck. consider EBL-ECU as a #1 with port fuel mod. Consider a pro products EFI manifold with fuel rails and FPR. Summit injectors. Cheap? add a 7.4L TBI unit and lose the injectors. Add a TPI FP. Plumb it witrh Aeroquip push fit hose. what am I missing?
Old Jun 29, 2010 | 10:27 AM
Saabster's Avatar
Car: 89 Camaro RS
Engine: LO3 TBI
Transmission: 700R4 => WC T-5
Axle/Gears: 3.42 Open Diff
Re: Tbi to HSR
I have long been debating this sort of setup versus the HSR. Technically the HSR's tunnel ram design with large plenum should be superior. I think the plumbing of the fuel is a wash for either conversion. I think the advantage of the single plane EFI setup is that no throttle linkages need to be messed with and you can use the TBI throttle, which goes neatly with all the sensors you'll likely need.
Old Jun 29, 2010 | 10:59 AM
Ronny's Avatar
Re: Tbi to HSR
For a few more $$$ you can use Edelbrock low profile neck with an ebay LS TB. I bet that flows more than 7.4L TBI.
Old Jun 29, 2010 | 12:07 PM
MTXaudioSYSTM's Avatar
Car: 90 formula
Transmission: auto
Re: Tbi to HSR
if u wanna swap to tpi your already on a good path for choosing the hsr.
Old Jun 29, 2010 | 12:26 PM
Saabster's Avatar
Car: 89 Camaro RS
Engine: LO3 TBI
Re: Tbi to HSR
I'm sure it does, a 7.4 only flows 650 cfm or so and LS1 are up to 750ish I believe.
I'm still not convinced that's better than a HSR. The HSR is $510 for the intake and the rails. And the rail kits comes with everything, lines to connect the two rails and a non-adjustable regulator set at 3 bar. Most of the other rail kits seem to be the rails and mounting hardware only. The HSR uses a standard TPI throttle, so it can use the TPI throttle cable.
Old Jun 29, 2010 | 01:16 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: Tbi to HSR
I been looking at the ebl but don't know exactly what I would need it also looks almost as expensive as if I go with the hsr.
Old Jun 29, 2010 | 01:18 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: Tbi to HSR
The reason I would like to go wih tpi is because I already have complete tpi but don't have the harness and ECM, but I was thinking of selling it then buying my self a HSR instead of droppng the tpi.
Old Jun 29, 2010 | 02:17 PM
Car: 90 formula
Transmission: auto
Re: Tbi to HSR
true but you will still need the sensors and such remember.
Old Jun 29, 2010 | 02:24 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: Tbi to HSR
Well I seen that I could use most of he tbi sensors on the tbi and I also have some from he tpi that it included on the purchase.
Old Jun 29, 2010 | 02:44 PM
Ronny's Avatar
Re: Tbi to HSR
SLRVETTE has a thread on his conversion from crossfire TBI to HSR. He used EBL-ECU if I am not mistaken. On corvetteforum he has a similar thread with more photos I believe. He won his HSR from Holley in some promotion I recall.
Old Jun 29, 2010 | 03:01 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: Tbi to HSR
Were can I find these were he swapped from tbi to hsr at right here or in another website
Old Jun 29, 2010 | 03:13 PM
Ronny's Avatar
Re: Tbi to HSR
He has several threads here. This is the main one I believe. Search "slrvette"
Also has threads on crossfire forum and corvette forum.
https://www.thirdgen.org/forums/alte...onversion.html
Old Jun 29, 2010 | 03:38 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: Tbi to HSR
Alright thanks I will take some time and read that
Old Jun 15, 2012 | 12:15 PM
slrvette's Avatar
Car: Corvette
Engine: 388 HSR custom Cam see sig
Axle/Gears: D44 3:45
Re: Tbi to HSR
Ron is right, I have done this swap. Its very easy. The best thread I have with all the info is here
smokinvette.com/corvetteforum/showthread.php?t=30862
You can also find me on corvetteforum... known as QWS
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
Gordonr1973
Sep 29, 2015 11:59 AM
