Work is killing me what do you think it will run (superram)?
Work is killing me, every single weekend and i cant wait to get a weekend off to make some runs. Its a 85 corvette
engine combo:
350
recently rebuild
stock bored honed with torque plates, pipe plugs inserted in deck for strength
total seal maxseal gapless top ring set
Scat procomp i beams 5.7 rods
stock trw pistons.
Milodon screen windage tray with crank scrapper
10.8.1 compression, checked
world products sportmans II heads bowl ported with 5 angle valve job
lpe 219 cam degreed in at 108.25
morel race hyd roller lifters
3/8 pushrods
140 lb valvespring
compcams promagnum 1.7 rockers .597/.597 lift
edelbrock lingenfelter ported 1205 intake
superram
48mm throttle body
24lb injectors
1 5/8 headers lts
2 1/4 true dual exhaust
magnaflow mufflers
3.07 gears
2400 stall
transgo stage 2 shift kit shifting at 5600
jesse azatto tune, im working on it; idles way to high, other wise runs great.
Engine was very carefully put together with proper clearances
While it was pointless to post some of the info i like thinking about it. If i can just get a weekend off i will see what it will do baseline, until then what do you think??
thanks
engine combo:
350
recently rebuild
stock trw pistons.
3/8 pushrods
140 lb valvespring
superram
48mm throttle body
24lb injectors
1 5/8 headers lts
magnaflow mufflers
3.07 gears
2400 stall
thanks
dhonda200
Aug 11, 2015 11:50 PM
