Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
LT4 intake on raised intake runner heads??
Old Oct 1, 2010 | 05:35 PM
2slow5.0's Avatar
Car: 91 Formula
Engine: 5.0 tpi slow
Transmission: WC t-5
Im tossing around some engine ideas to possibly utilise parts I already have and could use some guidance possibly. Is it possible to use a LT4 intake on a standard SBC but with 23 Degree raised intake port heads. I know the LT4 has raised intake runners and i think the same bolt pattern, but im not possitive. I know about the other mods to convert the LT1 intake to a standard SBC as I know they will also aplly. Is anyone else running raised runner heads (aside from vortec style) with EFI/TPI setups?
thanks for any advice
Old Oct 4, 2010 | 11:02 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: LT4 intake on raised intake runner heads??
I think you could use the Lt4 intake on a set of heads like the GM fastburns as they have a raise runner intake.
Not sure that would be worth while since an LT1 intake on a regular gen I head will provide same performance if not better performance if you use a better head than the fastburns.
Finding LT4 intakes is harder to do than LT1's.
I dont know of any other raise runner heads that one would be using on a street style sbc. AFR had the old 215's and I think trickflow had some at some point. Most dont use raise runner stuff anymore.
Old Oct 7, 2010 | 10:45 AM
InjectorsPlus's Avatar
Former Sponsor
All Pro, the KING of raised runner heads.. Lots of people are using them.
Old Oct 7, 2010 | 12:56 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Yeah but their normal 23 deg stuff is just as potent for a street/strip sbc. They make a good 220cc head that will handle 90% of most street builds. I dont know if the LT4 intake can even be ported to handle a head like the raised runner 245cc heads they have. The intake port may be very large for the LT4 to even cover. That head is a max race head IMO for 400-440+ inch motors turning 7500 rpm or more.
stalkier
Dec 6, 2015 11:25 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
anesthes
Aug 8, 2015 09:37 PM
