Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Which Stealth Ram do I have?
Old Jan 6, 2011 | 06:42 PM
redrummer's Avatar
Car: '88 Trans Am GTA
Engine: 5.7L L98
Axle/Gears: 3.27 Aussie 9 Bolt
I picked this Stealth Ram up a few years ago and never installed it and have since lost the installation manual and can't find any information through Google or Holley's website about it. Thought maybe someone here could help me out.
On the bottom, molded in the metal is 701R-126 and the date 02/06/07. On the opposite end, BB is molded into the metal. In the middle, an actual ink stamp shows 021407.
I believe this to be the non-vortec base, but I really don't remember. The only part numbers I can find anywhere online are 7542, etc.
Old Jan 6, 2011 | 08:24 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Which Stealth Ram do I have?
Vortec only has 4 bolt holes per side; reg SBC has 6
7542 is Vortec base
http://www.summitracing.com/parts/WND-7542/
7540 is reg
http://www.summitracing.com/parts/WND-7540/
Old Jan 7, 2011 | 07:32 AM
redrummer's Avatar
Engine: 5.7L L98
Thank you so much. Now I just need to sell it so I can get the Vortec version to use with my AFR 190 heads.
From what I can tell I will only need to sell the base. I can reuse the fuel rail and plenum, right?
Old Jan 7, 2011 | 07:48 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Only the base is different
Probably be more saleable as a complete unit ( base and plenum ) and buy whole new Vortec setup
Not many looking for base only unless you can find someone with opposite problem to you to swap bases with
Old Jan 7, 2011 | 09:39 AM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Axle/Gears: 2.73 posi
afr 190's have the standard sbc bolt pattern,,, at least mine do
Old Jan 7, 2011 | 10:11 AM
redrummer's Avatar
Engine: 5.7L L98
Looks like I need to look into things a little more. AFR's website says they're Vortec heads but wanabe03ss says his have the standard sbc bolt pattern. I'll do a mockup after I get the other head installed this weekend and go from there.
Old Jan 7, 2011 | 10:50 AM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
If you have these 2 bolt holes in the center its a standard bolt pattern
Old Jan 7, 2011 | 01:31 PM
pondriver's Avatar
Car: 1992 Camaro ZO3
Engine: 350 HSR
Axle/Gears: 9 bolt/3.70's
AFR makes a vortec head model 912
http://www.summitracing.com/parts/AFR-912/
I've been thinking about swapping to standard heads on my car since there are many more options. Might be interested in swapping intakes.
Old Jan 7, 2011 | 01:35 PM
redrummer's Avatar
Engine: 5.7L L98
Well, well, well. Interesting turn of events. I went out to the garage to check for those bolt holes and found that they in fact are there, but they look different from yours. Name:  IMG_3116Small.jpg
I did a quick mockup just holding the base against the head and all the holes line up. Am I good to go?
Old Jan 7, 2011 | 02:17 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
You should be all good, I wonder if my heads were shaved on the intake side? My intake valves are 2.05 and the ports are professionally blended. the machinest who just redid the springs and valve jobs said it looked like AFR did the work...... I dont know for sure.
Old Jan 7, 2011 | 02:54 PM
redrummer's Avatar
Engine: 5.7L L98
I see a couple of things that suggest yours were shaved. Maybe it was for hood clearance?
The big part that drops down between the bolt holes is a different size (yours is bigger) and the distance from the edge of the hole to the edge of the face is different (yours is smaller). You're also missing that big, fat lip up at the top. Either that or they changed the casting somewhere along the line. Kind of makes me wonder because mine has that extra hole between the bolt holes.
Old Jan 7, 2011 | 03:32 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Am I good to go?
With the different bolt angle on those holes ,your heads appear to be bolt on replacements for '87+ cast iron heads ; bolt angle is 72 degrees vs 90 degrees for reg ( pre '87 ) heads
The HSR base should have the center bolt holes elongated to fit either style ; at worst you can file the holes out
That would be the feed for the stock EGR valve which the HSR does not have
HSR will just seal that hole
Linson
Oct 24, 2025 02:00 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
L98GTA87
Oct 19, 2015 10:43 PM
mfp189
Sep 27, 2015 09:25 AM
R3500
Sep 8, 2015 10:12 PM
