Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Throttle body options?
Old Jan 31, 2011 | 12:54 AM
88gunmetalgta's Avatar
I'm gonna be ripping out the 305 TPI in my TA and putting a 383, and I'll be using the victor E EFI intake with an LS1 Throttle body.
searching ebay gives tons of results for LS1 throttle bodies, and I was wondering if there is any particular PN that would work the best for my application. The only difference I know about is the drive by wire, and cable linkages, but there has to be more differences than that.
Any info/personal experience would be appreciated.
Also, an 80mm unit should flow plenty enough for a 500 hp 383 right?
Old Jan 31, 2011 | 02:21 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Throttle body options?
Most of the LSx guys with heads/cam make 500 hp on motor and run the Fast 90mm stuff. Anything in the 85-90mm range would be best, but it is possible to see good power using a ported out stock LS1 TB which I think would be in the 78mm range. 80 would probably work ok.
You'd want the cable driven models. Run the 4th gen fbody throttle cable and fab up a simple mount to connect it to the elbow. Really not much of a difference anywhere else that I know of. Some earlier years LS1 tb's had different throttle springs (brown colored and blue colored) but no idea whats the difference between them. If you have a 700r4 you will need to figure out how to mount the TV cable to the TB.
Azrael91966669
25
Jun 20, 2017 04:04 AM
italiano67
Dec 11, 2016 09:21 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
