HSR - Fuel pressure: Running vs. not Running
Car: 1985 Chevy Camaro Z28
Engine: 5.0 LG4
Hello,
For HSR guys, please share your Fuel pressure when running, vs. not running. Also, please share your base timing.
Mine is a 1986 305, stock heads, with performance cam and HSR.
Car: '91 Z28 L98 G92
Engine: Modded L98
Transmission: Modded 700R4
Axle/Gears: Modded 10-Bolt
Re: HSR - Fuel pressure: Running vs. not Running
44psi w/ vacuum connected; 52psi w/ vacuum disconnected. 'Not running psi?' 0 after fuel system bleeds-down. Base timing- 6* BTDC @ ~ 800 RPM, trans in Drive.
Bill
Bill
Car: 00 SSEi / 94 C4
Engine: 231 / 383
Transmission: 4T65E / ZF 6sp
Axle/Gears: 2.93 / Dana 44 3:45
base timing on heavy mods 14deg @ 850 (HSR loves timing) 45PSI with 50# inj tuned
but I see you have a 305 and stock heads
Not running??? around 28PSI on my combo heavy hesitation
Car: 92 rs
Engine: 355 stealth ram, dart heads, S480
Transmission: 4L80E
setting at 42lbs with 30lb injectors timing 12deg base 34 total
Car: 1988 Pontiac Firebird
Engine: 305 LT1 intake&heads
Transmission: TH700r4
Axle/Gears: 3.73 10bolt GM
30lb SVO inj, pressure raised to 50psi, base timing 10 deg, total deg @900 RPM = 25
best regards
best regards
theshackle
03-05-2017 06:37 PM
92camaroJoe
08-13-2015 06:07 AM
