HSR Problem: Figured out.
Car: 1985 Chevy Camaro Z28
Engine: 5.0 LG4
Well, after messing with my Fuel Pressure, IAC, and TPS, I FINALLY hooked up a timing light to make sure that I had set my base timing correctly when I put the engine back together. Guess what? I was WAY OFF!
Instead of being at 6 degrees BTDC, I was retarded 4 degrees ATDC. WOW.
As soon as I rotated the distributor, my idle came back up about 100 RPM, and I KNEW I had found the source of my rough running problem.
I have been running today at 6 degrees BTDC, and WOWEE! Did that ever wake up my car!!! I am very happy with the Stealth Ram now, together with my other mods. Still more tweaking, but I am MILES ahead of where I was. The car ROARS and pulls like CRAZY.
Moral of the story: Always check your base timing with a timing light on these cars!!!
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: HSR Problem: Figured out.
No way can you drop a dist in a engine and THINK timing is correct
86CamaroDan
09-29-2015 10:08 PM
