Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
LT1 Intake swap-----
Old Mar 24, 2011 | 09:25 AM
stingrayguy's Avatar
Hey guys,
I was about to buy a hsr.. when a buddy told me I could have his lt1 intake. I have seen many people have great luck with it, and pull some good power how the miniram works.
So I got a 96 lt1 intake ported to 58mm and a bbk 58mm TB.
I have done lots of reading on the swap.
I don't want to cut the hole myself, lt1intake is long gone. I'm looking for someone who has done this swap to cut if for me,
Anyone?
I did see a guy made a template off a stock tpi base. But my problem is making that 1/4" shim with the 5 degree angle.
Ideas?
I plan to run this intake on a set of afr 195s
Old Mar 24, 2011 | 11:26 AM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Re: LT1 Intake swap-----
Doesnt cost much at all to have a competent machine shop do that, it has to be right on the money or youll have issues with your dist gear.
Old Mar 24, 2011 | 11:28 AM
right, thats what I don't want to try it myself.
I wanted to know if anyone on here has done it and its still running..
Old Mar 24, 2011 | 04:43 PM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
I don't think cutting the hole is as big deal as you make it sound, as long as it's in the right area the shaft will align itself in the hole just a matter of getting the proper hight with the shim and angle if you want a nice flat non-leak seal. Though you really got to ask yourself is it's worth the trouble over getting a HSR which is why you rarely see this swap anymore.
Old Apr 11, 2011 | 10:46 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
No disrespect intended but....
if you not comfortable with cutting the big hole in the back then maybe this swap just isn't for you. Maybe you should go with something that's a direct bolt on.
Old Apr 11, 2011 | 12:08 PM
yup, Problem solved, I bought a hsr
Old Apr 11, 2011 | 05:25 PM
Firebat's Avatar
FYI for those interested in LT1 intake - thirdgen.org member Z69 was selling the 5 degree angled washers for the rear dizzy a few months ago.
Old Sep 5, 2013 | 03:13 AM
kyleiroc88's Avatar
Car: 88 iroc-z, 86 trans am
Engine: lt1
Transmission: 700r4 tci streetfighter
Axle/Gears: '02 10 bolt, slp auburn diff
None of these replies are very helpful. I believe he was asking for a member or the name of a machine shop that has a jig to correctly place the hole. I would be very interested in this as well. Lt1s are cool but optispark and 4th gen wiring sounds terrible. If i could pay someone to drill a hole and mill off the egr (not hack it off) i could bolt in an lt1 under the hood w my distributor and 3rd gen harness by reusing my tpi electronics. Anyone know anyone who could do this
Old Sep 5, 2013 | 06:08 AM
rdhanded2's Avatar
Top Answer: 1
Car: 91 TA / 91 Formula
It is too bad no one offers this service anymore. I would be interested in a setup as well.
Old Sep 5, 2013 | 01:13 PM
Drac0nic's Avatar
Personally if you're going to do this I'd go to the phone book/net/whatever and find a local machine shop, tell them what you're wanting to do and see if they'll handle it. The outer most bolts of the LT-1 intake are the same as a production 350, so that's where your reference point should be. Grab another SBC intake, use those holes to locate the dizzy hole and then go to town with it.
PS:
Another thing you LT-1 guys can do is go the exact OPPOSITE of the LT-1 intake swap and convert a gen I manifold over to fit the LT-1. That means you can stuff one in say a TBI car or use a TPI/HSR intake if you wanted to.
RS Chris's Avatar
Car: 1991 RS
Engine: 5.0
Neither is bumping a two year old thread with more useless info.
Old Sep 5, 2013 | 07:45 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
The LT1 intake swap is dead these days unless you can save $$$ by doing all the work yourself
The HSR is a very cost effective bolt on install with no need for extra plumbing and weird adaptions
Old Sep 5, 2013 | 07:49 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Originally Posted by Drac0nic
convert a gen I manifold over to fit the LT-1. .
My Victor E SP intake came off a LT1, PO enlarged the holes and used thick washers.
He was using the Opti as a spark trigger only with a rear mount dist for the plug wires ; best of both worlds.
New2Chevy
Sep 28, 2015 12:35 AM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
88 TA GTA
LSX and LTX Parts
Sep 11, 2015 11:31 PM
toronto formula
Sep 10, 2015 07:31 AM
L0tuS
Sep 4, 2015 11:16 PM
