FORD injectors opening time
Car: 1988 Pontiac Firebird
Engine: 305 LT1 intake&heads
Transmission: TH700r4
Axle/Gears: 3.73 10bolt GM
Can anybody tell me Injector Opening Time for Ford Racing 30# (part no. M-9593-B302) ?
Best regards
Best regards
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: FORD injectors opening time
http://www.calibratedsuccess.com/***...%20Article.pdf
http://www.fordracingparts.com/parts...-9593-b302.pdf
sounds like your going to have to play with this after you get it going 1.081 ms
Yes i have read that one before asking question but in Megasquirt i need to input Injector Opening Time described as:
is the amount of time required for the injector to go from a fully closed state to a fully opened state when a 13.2 volt signal is applied. Since fuel injectors are electro-mechanical devices with mass, they have latency between the time a signal is applied and the time they are in steady-state spraying mode. Typically, this value is close to 1.0 milliseconds. Note that the closing time should theoretically be subtracted from the opening time, but the closing time is generally very small compared to the opening time.
I need to know this value.
Best regards
Best regards
Engine: Lb9
Transmission: M20
1.081 ms I think is the lowest starting point, depending on fuel pressure
mdtoren
Aug 16, 2015 05:45 PM
