Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Distributor Dilemma
Old Jan 27, 2012 | 06:42 PM
87SLEEPER's Avatar
Car: 1992 RS B4C
Axle/Gears: 3.23 10 bolt limited slip
Distributor Dilemma
I think I have heard that my stock HEI distributor is too big for the StealthRam I will be adding shortly to my 355 build. Just by looking it does seem like its gonna be close. If this is the case then what would be a good plug n' play replacement for under $300. Is it possible to build mine but with a smaller cap?
Thanks in advance
( pun intended. Lol )
Attached Thumbnails Distributor Dilemma-imag0301.jpg   Distributor Dilemma-imag0159.jpg   Distributor Dilemma-img_20110902_163358.jpg
Old Jan 27, 2012 | 07:59 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Distributor Dilemma
Any small cap dist with remote coil from a late 3rd Gen or 87 -95 TBI truck
Rebuild from Auto Zone or NAPA
No you can't make your HEI dist into a small cap dist
Old Jan 27, 2012 | 08:13 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
be careful with the early 90's tbi truck ones they have a larger base starting in about 92 and some tbi cars have the large base as well.
Old Jan 27, 2012 | 08:17 PM
87SLEEPER's Avatar
Car: 1992 RS B4C
Thanks for pointing me in the right direction. Glad to hear I can get away with freshening up a gm piece and it sounds like it will be under $100. Good news!!
Old Jan 27, 2012 | 08:18 PM
Engine: Lb9
Transmission: M20
Old Jan 27, 2012 | 08:37 PM
87SLEEPER's Avatar
Car: 1992 RS B4C
Would this be considered a Small Cap. The pictures on the autozone website dont give me that much to look at for reference.
http://www.jegs.com/i/JEGS-Performan...oductId=772089
Great comparison BTW
Old Jan 27, 2012 | 08:40 PM
Engine: Lb9
Transmission: M20
thats it, its easy to make a adapter for it to plug into your current harness. you will also need to buy or make a harness from the icm to the coil.
Old Jan 27, 2012 | 08:47 PM
87SLEEPER's Avatar
Car: 1992 RS B4C
So the connectors on this unit will need to be modified or my harness? This distributor looks amazing but I really don't like the idea or splicing the factory wiring if I can help it. It's an OCD thing.
Old Jan 27, 2012 | 08:50 PM
Engine: Lb9
Transmission: M20
gm 12048976, go to the junk yard and get the connectors easy harness to build
http://www.ebay.com/itm/Chevy-TPI-HE...b#ht_728wt_733
Old Jan 27, 2012 | 08:59 PM
87SLEEPER's Avatar
Car: 1992 RS B4C
Noticed this description on that add. My cap is an 87 so maybe I have the right one then. I have an external coil already. I wanted to have the distributor ordered and on hand before I did the swap but I guess it would be wiser to try and fit mine when the time comes before I buy something I don't need. Does Large Cap = Coil in Cap? Thanks again.
"Looking to change from an 85-86 large cap distributor to an 87-92 small cap distributor? This kit contains all you need to wire it in properly. Includes a large cap to small cap adapter harness, distributor to coil harness, and coil power/tach pigtail. This kit is equivalent to the now discontinued ACCEL 74170 F-body Wiring Conv. Kit."
Old Jan 27, 2012 | 09:13 PM
Engine: Lb9
Transmission: M20
http://www.mouser.com/ProductDetail/...RLhYwWm%2fA%3d
http://www.mouser.com/Search/Product...lkG701UQ%3D%3D
http://www.ebay.com/itm/Dorman-Condu...#ht_2513wt_967
Old Jan 27, 2012 | 09:22 PM
87SLEEPER's Avatar
Car: 1992 RS B4C
Well it looks like no matter what happens when I get to this point I have some good info to fall back on. These links are great. This will really get me the performance I'm looking for while keeping the factory fresh look.
Old Jan 27, 2012 | 10:12 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Very interesting. you have taught me my one new thing today, thanx!
Old Jan 27, 2012 | 10:19 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Originally Posted by 87SLEEPER
"Looking to change from an 85-86 large cap distributor to an 87-92 small cap distributor? This kit contains all you need to wire it in properly. "
You don't have to use the GM dual connector coil that was used in the factory setup.
If going from HEI you have to splice the ign side connector for the coil into
the exiting wiring anyway so cheaper and easier to use reg coil
$25 gets you this wiring
http://www.eficonnection.com/eficonn...spx?ItemId=792
http://www.eficonnection.com/eficonn...spx?ItemId=936
and can use any coil that has reg terminals
Old Jan 27, 2012 | 10:21 PM
ctowen's Avatar
How can I hook up my 1979 hei distributor with a 4 prong module to my wiring in my 1989 Iroc ?
Old Jan 27, 2012 | 10:48 PM
Engine: Lb9
Transmission: M20
If your asking how to wire it use acc voltage to th hei and tach output. If your trying to replace it with a computer controlled small cap hei you need to get a new icm and notch the body of the distributor . Or get a large cap hei from a ccc or a 86 tbi or 85-87 tpi or vette
Old Mar 26, 2012 | 09:16 PM
jonarotz's Avatar
Car: 91 Z28
I just swapped out an accel billet small cap hei dist for a dual sync. If you're interested in it pm me.
Old Mar 26, 2012 | 09:42 PM
87SLEEPER's Avatar
Car: 1992 RS B4C
My stock remote coil fit fine.
Remote coil = small cap
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Jlanz55
Sep 29, 2015 08:55 AM
Damon
Sep 26, 2015 04:29 PM
