Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
FIRST Intake
Old Jan 30, 2012 | 03:07 PM
427F-Bird's Avatar
Car: 1986 Firebird / 1991 Formula
Engine: 350 4BBL / 305 TPI
Transmission: 700 R4 / T 5
Axle/Gears: 9-Bolt Posi / 10 Bolt Posi
FIRST Intake
So I just got a FIRST intake with fuel rails and injectors for $120, minus 3 of the runner bolts and in need of new gaskets. Would it be worth the time and effort to install this on a stock 91 TPI firebird, and if so, what kind of gains could I expect. I also have an 87 with a 400SBC that still has all the wiring to convert back to TPI, would it be better to wait til im back in new york and install it on that? Any info would be appreciated. Thanks.
Old Feb 6, 2012 | 02:00 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: FIRST Intake
Depends on what you want to use it on, but it will gain power on a stock 91 TPI motor. 20hp is likely I'd say on a 350. 305 may see alittle less gain since it doesnt require as much airflow. I know my HSR swap on my L98 gained a good bit of mph and ET at the track. Seen many bolt on aftermarket TPI setups on stock longblocks do the same thing.
FIRST will support the 400 sbc well too so it can be used on that.
customblackbird
Oct 1, 2015 04:30 PM
85 Jimmy
Sep 30, 2015 07:56 AM
jerflash
Sep 24, 2015 03:11 PM
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
