Anyone know the size of the IAT hole on the SuperRam?
Car: 1989 IROC-Z
Axle/Gears: 4th gen rear with 3.42
The threads in my SuperRam for the IAT sensor are all jacked and need to be retapped, does anyone know what size tap I need to use? I believe it needs a 3/8" pipe tap but I want to make sure before I screw it up worse.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Anyone know the size of the IAT hole on the SuperRam?
If you can't clean the threads up ,tap it 1/2" NPT and use a brass reducer bush
Engine: 4++,350 & 305 CIs
Just a quick FYI:
Its called a MAT if its in the manifold and a IAT if its in the ductwork b4 the T-body.
Linson
Sep 21, 2015 01:08 PM
