Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
a few ? on hsr, 409 cam, 113 vette heads and stall
Old Feb 29, 2012 | 12:54 AM
Sojer's Avatar
Car: 1987 IROC-Z red t-top
Engine: Nothing much
Transmission: I wish t56
Axle/Gears: 9bolt 3.27 4sale
Two engines two cars
First mine stock bottom end 70k on it lb9 87 iroc 3400lb 700r4 9bolt shorty headers
With 113 heads hsr zz4 cam or close to it 1.5 rollor rockers
Can I use diff lifters that don't come with the cam
What size stall I here diff stuff 2200-3200 its a dd
Second summit 355 2pc rmc 409 cam??? 84 15th ann trans am 700r4
Would 113 heads work what intake what carb what stall its a dd too
What hp would it will see.
Old Feb 29, 2012 | 02:20 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: a few ? on hsr, 409 cam, 113 vette heads and stall
Originally Posted by Sojer
Can I use lifters that don't come with the cam
With a roller cam you can use new roller lifters or good used ones from another cam on any lobe
With a flat tappet cam ; either the exact lifters that came off a lobe or new ones; no swapping between lobes or different cams
lt500r55
Sep 1, 2021 01:30 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
86White_T/A305
Aug 17, 2015 12:16 AM
TreDeClaw
Aug 14, 2015 06:58 PM
