How do I take care of EGR after HSR install?
Guest
Posts: n/a
Hey guys just wondering what needs to be done to disable the EGR after I install my HSR? Some say plug it, some say disconnect all hoses, some say just removed it from your chip. I am going to tune after the HSR install I just won't be able to do it immediately as I have no tuning equipment and will probably have to rely on mail order tune. Thanks for the help guys!
Engine: 4++,350 & 305 CIs
Re: How do I take care of EGR after HSR install?
MAF cars you can just unhook it all. SD cars, I'm not 100% sure if it works the same but I think so. Try it, if it sets a code, clear it and have it removed in the chip.
I know the knock sensors on MAFs can be unpluged an not set a code and SD cars you can't without a code.
Remove everything and disable the Code 32 flag... done!
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
You would also want to set the min mat vs egr to the max setting to avoid timing advance.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
The spark is advanced when EGR is active
The ECM will still think EGR is there , it only monitors if it is working of not ; no feedback to say it has been removed completely
And because it does not know it is gone it will continue (try ) to operate it and will advance the spark as it is programmed
As tunedperformanc and Twin_Turbo mention you have to disable EGR on the tune so it is never activated
which means because it is not activated , you never get a code from it not working
Code 43
http://www.chevythunder.com/maf_esc_module_code_43.htm
On start up the ECM advances the spark enough to generate knock so it knows the KS is working.
If it doesn't see it working it throws a 43 and will prevent spark advance over 1500 ? rpm
Knock sensors are calibrated specific to a engine /ECM which is why you must use the correct one
https://www.thirdgen.org/forums/post...21-post12.html
Code 43
Code 43
Code 43
With the KS, I have 6 maf cars (untuned, timing bumped(temp) around here with many many miles that its unplugged on and they have always run waaaay better than with them plugged in and no code.
If you run crappy fuel, def leave it plugged in and working.
My KS has been unplugged for 180,000 plus miles and never ever set a code 43. Same with EGR.
Yes it should all be tuned out and turned off but will work until that can be done.
1992rs/ss
16
Jan 28, 2016 09:58 PM
mdtoren
Aug 16, 2015 05:45 PM
