Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
1206 ready single plane EFI intake
Old Nov 14, 2013 | 12:46 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
What options are there?
/N.
Old Nov 14, 2013 | 07:21 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: 1206 ready single plane EFI intake
/N.
The hurricane can be ported to 1206 with minimal effort. That is what I did when i switched to the AFR210 heads.
-- Joe
Old Nov 14, 2013 | 09:56 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
I dont if anything comes out the box 1206. Most are 1204-1205. My victor e is just under 1205 and i ported to 1207 for my new heads. Plenty of material. Its a huge port
Old Nov 15, 2013 | 12:20 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Ok, thx. Just so I dont have to weld it to be able to portmatch it.
Old Nov 18, 2013 | 03:05 PM
Cosmik Debris's Avatar
The World Products Motown is used by Accel in their EFI system, it is 1206. This is the standard intake, you can get an EFI ready one from Accel.
http://www.theengineshop.com/product...rb-flange.html
Old Nov 18, 2013 | 09:32 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
accel has it under the name ProRam. with fuel rails the name on the intake in a accel box. is Motown/word products
bolt on 1206. ports are even not mismatched like the lower cost intakes.
bolts right up to AFR220 Eliminator heads also
below is the Motown/accel intake. set up for EFI. black out line is from the felpro 1206 intake out line.(fits better then outline.)
I let it drop down to show how close it is.
what it looks like
below is 1206 on AFR 220 Elmtr Heads.= true bolt on. no work needed.
Old Nov 19, 2013 | 05:51 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
What does the intake + fuel rails go for these days?
-- Joe
Old Nov 19, 2013 | 08:46 AM
efiguy's Avatar
-- Joe
Pm'd you. I'm a dealer.
Old Nov 19, 2013 | 09:02 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Shoot me a price too if you can. Thanks
It looks taller than a victor e but victor doesnt have vacuum ports around the carb flange. Looks like pro ram has built in spacer
Old Nov 19, 2013 | 09:14 AM
efiguy's Avatar
It is basically a Motown intake with the bungs drilled and matching rails.
My dyno guy says that that's one of the best small block single planes on the market.
Pm'd you.
Old Nov 19, 2013 | 10:46 AM
Stangski09's Avatar
Car: 1988 Pontiac Trans Am GTA.
Engine: 385 stroker sbc
Transmission: TKO600
Axle/Gears: Moser 9" 3.70 Wavetrac
i just picked up an RHS efi single plane. It's a 1206 port, very nice piece
Old Nov 19, 2013 | 11:52 AM
Stangski09's Avatar
http://www.racingheadservice.com/rhs...fuel-railshtml
Comes with fast fuel rails too.
Im going to go with the red anodized fast 1375cfm 4bbl tb as well.
And a teaser with the rails half assembled
Old Nov 19, 2013 | 12:15 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Pm'd you.
I wouldn't doubt it. What is the total height?
When I did this chart back in 2005, it was a 1204 port and 4.875" tal.
My hurricane gets the job done, but if it was a half inch shorter my trottle body wouldn't rub the underside of the hood.
-- Joe
Old Nov 19, 2013 | 08:02 PM
Accel Pro Ram with rails set to bolt on summit had them at $485
one of the chevy mags did a test of 15 to 18 intakes and this one came out on top.
Old Nov 20, 2013 | 12:15 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
http://www.carcraft.com/techarticles...t/viewall.html
Old Nov 21, 2013 | 10:01 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Maybe there are to different versions of the Accel intake. I have the Accel ProRam and it was set at a 1205 intake gasket. Porting it out to a 1206 may require welding as it might get thin walled in some areas.
Old Nov 22, 2013 | 05:38 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Hrmm. Interesting. Looks like for the single planes, the Hurricane/procomp/el-china is a good deal. Made more power than a lot of the high dollar intakes. Under $200 on ebay:
http://www.ebay.com/itm/EFI-READY-SBC-CHEVY-SINGLE-PLANE-ALUMINUM-INTAKE-MANIFOLD-3000-7500-/181174344910?pt=Motors_Car_Truck_Parts_Accessories&hash=item2a2ed51cce&vxp=mtr
-- Joe
Old Nov 22, 2013 | 03:50 PM
Tibo's Avatar
Car: 1991 Z28 Vert
EFI Ready SBC Chevy Single Plane Aluminum Intake Manifold 3000 7500 | eBay
-- Joe
I looked into the hurricane but found a great deal on mine for the whole setup. I think the acell has a longer runner by one inch, so less hood clearance, just FYI.
Old Nov 23, 2013 | 09:48 PM
The Motown EFI single plane sold in the accel box under the name ProRam
in the last 2 years is a bolt on 1206 felpro gasket. and can go up even larger with port work. no welding. the pic I posted is out of box. bolt on and play 1206...and comes with fuel rails. for the $485 price
Old Nov 23, 2013 | 11:15 PM
Tibo's Avatar
Car: 1991 Z28 Vert
I have owned mine for two years and I had bought it from another member. Might explain the difference.
Old Nov 25, 2013 | 07:20 AM
3genpio's Avatar
Car: Trans Am
Engine: 383 Accel ProRam single plain EFI
Transmission: t-56 Spec #3
Axle/Gears: 4 gen 3.73:1
I think Tibo is right.
I have also Pro-Ram and it was far away from 1206...it needs some porting to fit 1205, take a look at the pictures.
black markes is for 1205...
Old Nov 26, 2013 | 03:36 AM
well this is a pic of my ProRam by Motown (in a accel box)
and it looks nothing like yours.. mine fits the felpro 1206 intake gasket.
out of the box. yours and mine are 2 dif casting..mine has the larger ports.
so they don't use what ever casting they did a few years ago.. accel has stopped a few things...
note I droped the gasket down and out lined it for pic.
Old Nov 26, 2013 | 03:45 AM
this is the same gasket on my old heads 1206 can be seen(heads are TFS)
Old Nov 26, 2013 | 03:58 AM
when I got my Accel ProRam this is what came in the Accel box
Motowns Single Plane EFI
Takes felpro 1206 gasket for the same fit on the AFR 220 heads for the SBC 427. (looks like every thing is a bit bigger now )
Old Nov 26, 2013 | 05:58 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
So Accel gave up making their own intakes, and simply resell someone elses?
I wonder when they are going to give up on their junk EFI controller and go with something more modern
-- Joe
Old Nov 26, 2013 | 09:26 PM
-- Joe
they also don't cover any of there parts with the Life time Warranty.any more.
that to was dropped. so every body can buy Msd And ?
accel proram. 100% bolt on felpro 1206 intake gasket
92projectcamaro
Jan 18, 2016 08:00 AM
beastin91rs
Oct 9, 2015 07:38 AM
355tpipickup
Aug 29, 2015 10:47 PM
Jake_92RS
Aug 11, 2015 10:39 AM
