Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Somewhat different accel base
Old Jan 12, 2014 | 03:58 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
I have a few of the superram intakes and noticed this one is odd with the E instead of a R. For registered trade mark. has anyone ever seen this ?
Is it the rare lt1 intake made for linginfelter ?
http://forums.corvetteforum.com/c4-p...super-ram.html
Old Jan 12, 2014 | 04:03 AM
Engine: Lb9
Transmission: M20
Re: Somewhat different accel base
Pic1
Old Jan 12, 2014 | 04:04 AM
Engine: Lb9
Transmission: M20
pic2
Old Jan 12, 2014 | 04:45 AM
mjdavis68's Avatar
Car: 88 IROC Z/28-under re-construction
Engine: 5.7 Tuned Port
Transmission: It's in there....
Axle/Gears: 9 bolt Borg-Warner
I know this doesn't have ANYTHING to do with your question but that's what i'd like to have is a Super Ram/Injectors/Vortec's/GM's hot cam upgrade.....
Old Jan 12, 2014 | 05:01 AM
Engine: Lb9
Transmission: M20
I would be curious how much hp you would be giving up at the higher rpm range sd intake vs accel. those are some small inlets.
Old Jan 12, 2014 | 05:24 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Has the hole for the Gen I dist machined so I doubt it .Also has the 4 center holes machined for either early or late style Gen I heads
IIRC .
the Gen II version was identical to the Gen I version except for the different intake bolt pattern and lack of dist hole
Old Jan 12, 2014 | 05:27 AM
Engine: Lb9
Transmission: M20
I thought the Lpe 383s in a few 4th gens were running a dizzy and a dfi 7 ?
but if the bolt patterns wrong its wrong. I don't have any lt engines.
E means its experimental LOL
Fanatic1074
Oct 3, 2022 05:57 AM
bjpotter
Oct 4, 2015 07:48 PM
ndndndnd
Sep 28, 2015 08:00 AM
efiguy
Sep 27, 2015 01:30 PM
