project89
close
Quote:
i what part of the intake did u have to cut ? got any pics of how urs showed up ?Originally Posted by robertfrank
Mine came in and as previously mentioned it SERIOUSLY needs portwork to make it work. Since I'm running this intake on an LT1 i had to shave an 1/8th of an inch off of each side of the intake in order for it to sit flat due to the valve cover rails being larger on the LT heads. I am now in the process of porting the intake to match the heads as we speak. I'll post up pics when I'm done. my first one was halfway decent the second needed a bunch more work then the first
robertfrank
close
- Join DateApr 2004
- LocationSalt Lake City, Utah
- iTrader Positive Feedback100
- iTrader Feedback Score(27)
- Car1988 camaro "SS"/ 1991 305/T5
- Engine383 LT1 in progress/LT1TBI 355 soon
- TransmissionProbuilt 700R4 3600 stall/ T5
- Axle/GearsMoser axles, 3.42 Eaton Posi
- Liked:62 Times in 44 Posts
The most grinding needed was on the end most runners on each side. I swear porting this intake is almost exactly like porting a cylinder head. To smooth it out I've had to take out almost more than a 1/4 inch and blend it in some spots.
project89
close
The most grinding needed was on the end most runners on each side. I swear porting this intake is almost exactly like porting a cylinder head. To smooth it out I've had to take out almost more than a 1/4 inch and blend it in some spots. u didnt take the taper out of the runner did ya ? i ended up doing the entire runner on mine to keep the nice taper from top to bottom
if u did take out the taper id be curious to see what results u get in the lower rpm range
are u going to radius the runner inlets under the plenum?found a guy who did some testing on one of these and picked up 35+ cfm just by radiusing the inlets
robertfrank
close
- Join DateApr 2004
I'm trying to get the runners to flow as straight a shot as possible yet keep them the same width as possible. From what i saw with the intake set on the heads (that are already ported) the walls closest to the pushrod pinch almost formed a soft "W" and in my mind would cause a nasty flow imbalance. So i'm trying to straighten that up as much as possible in the intake before it even reaches the head. I am indeed doing a soft radius at the top of the runners. I'm even doing the same to the outlet of the upper plenum as well.
project89
close
keep us posted on ur progress , im working with a friend on doing something pretty radical on the runner entrys , for a high rpm 406sb
think a 4-1 header collector with a bullet in the center
something along these lines with the runner shortened 1-2 inches
with a nice trumpet bellmouth on the outer walls , which in order to get round we will have to machine down the outer walls and machine a billet piece to put back and weld into place
and on top will be a rather large custom plenum , the bellmouths will either be flat to the floor or raised 1 inchabove depending on what we come up with on his flow bench
robertfrank
close
- Join DateApr 2004
Nice. I'm not trying to go that extreme but just trying to maximize what is already there. My engine is an LT355, balanced stock crank with shot peened rods with an ARP rod bolt upgrade, stage 1 ported heads (runner pinch opened up to 1.07 with full bowl,guide and chamber work) xfi268 cam. I'm seriously thinking about putting a GT45 on this motor so piston selection is still up in the air. As far as the intake goes i'm also thinking about after all the portwork is finished, knocking out the bolt pillars and welding the upper plenum to the lower and making it a one piece.
robertfrank
close
- Join DateApr 2004
Here's some pics of what I did.
robertfrank
close
- Join DateApr 2004
robertfrank
close
- Join DateApr 2004
A few more
robertfrank
close
- Join DateApr 2004
here's what I started with, you can see from the outlines of the LT1 gasket I had quite a bit to go through to get it to match up. Truthfully, if someone wanted to just swap this intake onto a stock LT1 it would match up fairly closely without really any porting.
project89
close
nice job on the plenum and runner entrys
looks like the carbide got away from ya in a spot or 2 on the head side , are u using a non ferous burr?
any mor epics of the plenum did u paint it or how did u dull it out like that ?been thinking about hitting mine with a red scotchbrite pad sinc eim not a fan of the chrome look
robertfrank
close
- Join DateApr 2004
Carbide got away? What do you mean? If you are refering to the slight raise in one of the runners I didn't have much choice. Thats how far off it was stock. One side was almost dead on , the other side seemed like the runners were raised higher so i had to compensate. As far as the upper plenum goes, i hit it with a 60 grit on my mouse sander to knock the polish off and rough it up. I had some cast aluminum VHT paint left over from a set of headers i did awhile back so i used that. Luckily it was almost a dead match.
project89
close
ahh i see it now i didnt see it the first time around on ur layout pics.
without seeing that picture it look like the carbide bit in on ya and went to far was going to give u a tip to keep that from happening on aluminum
that plenum looks so much better like that i may have to do the same or i may just have it painted the same color as the car is getting painted
i wish the plenum came witht he same finish my valve covers did
robertfrank
close
- Join DateApr 2004
Those covers look sick. Overall I'm happy with the intake. I would've had to port a regular HSR the same way so its all good. If you haven't cut the top plenum yet be careful because it is SOFT. My bits chopped through it quick. I had to work very gingerly not to go to far. I'm still debating on knocking out the towers and just welding down the upper plenum.
The only one gripe i have with it though is that the stock bolts for my rails (the same as you have and the same ones that also work for the procomp/speedmaster Single plane efi intake) WILL NOT work. The pitch was wrong but upon inspection 1/4-20 bolts work fine and thread up tight. Also, I have to find out what size/pitch the tb mounting bolts are as the stock ones won't work either. I did find that stock TBI bolts thread up so if you know the pitch on them let me know.
Hey i was wondering what fuel pressure regulator you used with those ebay red fuel rails? also a pic of the fuel rails would be awesome!
project89
close
ill see if i can get u the size for the bolts i used on my tb , i had some laying in the bolt bin but dont rember the size of them off hand
vortec im using an areomotive regulator but u can basically use anything u like with it
project89
close
5/16 course thread for the tb
1/4-20 for rails
1/4-20 for rails
project89
close
btw i had to modify my throttle body so the linkage wouldnt hit the fuel rails.
ill take some pics next time im over at the shop but that prolly wont be till tuesday
Not surprised on the TB the HSR is very picky about which TB it uses. I have 3 here only 1 fit. As a dumb question, I was expecting some comparison pics between the HSR and the knockoff since you said you had both. How does the CSA of the runners compare? It seems smaller stock but ports out bigger on the Chinese one.
project89
close
Quote:
i never got the chance to do a side by side since i had to ship it back Originally Posted by Drac0nic
Not surprised on the TB the HSR is very picky about which TB it uses. I have 3 here only 1 fit. As a dumb question, I was expecting some comparison pics between the HSR and the knockoff since you said you had both. How does the CSA of the runners compare? It seems smaller stock but ports out bigger on the Chinese one. if someone else wants to measure an untouched hsr i do have another untouched china hsr on the shelf , i ended up with 3 of them lmao , i can do measurements just about every inch from plenum to head
project 89 how do you think this intake would do on a healthy 406 sbc.
project89
close
Quote:
i think it would do pretty damn well , im helping a friend prep one for a high reving 406 Originally Posted by kad5118
project 89 how do you think this intake would do on a healthy 406 sbc. its tought to beat a good efi single plane though too, if u can port it urself id go with the hsr on the 406 as it would be alot cheaper
Yea i was looking at the hurricane single plane intake as well.but after seeing this setup im leaning toward what you have.I already have a 58 tb on my tpi setup.Originally Posted by project89
i think it would do pretty damn well , im helping a friend prep one for a high revving 406 its tought to beat a good efi single plane though too, if u can port it urself id go with the hsr on the 406 as it would be alot cheaper
Caught me just in time before the install... FYI this is the vortec HSR
Any other measurements you guy want before i install let me know. Also every port was different on every hole Stock untouched HSR
project89
close
Quote:
Originally Posted by 1992Vortec
Any other measurements you guy want before i install let me know. Also every port was different on every hole Stock untouched HSR perfect and chance u have the tools needed to measure inside the ports?
Sorry I don't have the tools...
Hey so what did you do to modify the TB for the linkage? Im trying to get mine to clear the fittings coming out of the fuel rail.
project89
close
Quote:
let me see if i still have the pictures , if not i can take some more tommorowOriginally Posted by 1992Vortec
Hey so what did you do to modify the TB for the linkage? Im trying to get mine to clear the fittings coming out of the fuel rail. here san important note , this intake will not clear a stock hood , my amd 4inch steel cowl hood does not clear either , most fiberglass cowl hoods should be fine
my amd hood has a finished underside with a cutout for a 14 inch air cleaner , i need to trim about an inch of the opening for it to clear the throttle body
if u trim the underside of the stock hood it should fit just fine
project89
close
what i did was cut the normal throttle cable section off and am using what i bellive to be a carb/tbi throttle cable , it works perfect
robertfrank
close
- Join DateApr 2004
How did you get your rails to seat all the way down? Even with stock injectors sitting flush in the holes myrails sit literally a 1/4 inch to high. Plus, how did you run your regulator? It seems that these damn rails didn't come with enough fittings.
project89
close
How did you get your rails to seat all the way down? Even with stock injectors sitting flush in the holes myrails sit literally a 1/4 inch to high. Plus, how did you run your regulator? It seems that these damn rails didn't come with enough fittings. had to tap mine down with a rubber mallet to fully seat the injectors into the intake/rails , u have to enlarge the mounting hole sin the rails a lil bit
my regulator is remote mounted near the stut tower above the were the factory hard lines meet the factory rubber lines
napa made me my lines from the rail to the regulator was 27$ for 3 ft of hose + the 2 -8 fittings
from the regulator to the return line im just using fuel injection hose to the factory feed line that has been converted to be the return line
im also running the crossover on the back of the intake not the front , if u make a line 2 inches longer then what the rails come with it fits and clears the distribuor
both my feed line and return line feeding the regulator are on the front of the intake instead of the back
robertfrank
close
- Join DateApr 2004
I couldn't bother you for some pics of this could I? I'm trying to get EVERYTHING ready before I swap it onto the car.
project89
close
Quote:
sure but i wont be able to take pictures till this weekendOriginally Posted by robertfrank
I couldn't bother you for some pics of this could I? I'm trying to get EVERYTHING ready before I swap it onto the car. robertfrank
close
- Join DateApr 2004
Any pics?
project89
close
Quote:
sorry man i forgot about yaOriginally Posted by robertfrank
Any pics? Junior Member
Here are a few pic if you need any more let me know. The holes in the rails need to be drilled i had to go pretty big on mine to fit. I ran a 90 degree elbow off my passenger side rail and put my reg on it. The fuel rails didn't come with enough fittings to do everything i suggest getting 2 90 degree pipe to an fittings just for clearance but it depends on where you want to run your lines front or back. USE teflon tape on the pipe fittings trust me lol
Project89 what are you using for fuel management?
project89
close
Quote:
megasquirtOriginally Posted by 1992Vortec
Project89 what are you using for fuel management? robertfrank
close
- Join DateApr 2004
Hahahaha I have that EXACT regulator lol. How is it working for you? Did you go back to a regular stealth ram?
The regulator works good i have no complaints but i need to go standalone to control all this extra air I'm looking at the EBL4. I bought the Vortec HSR. Project89 had both at one time and ended up using the china special because he could do more amazing porting as you can see from the pics.
These are $200 now shipped on ebay...
-- Joe
-- Joe
mrestrictrplate
close
besides fuel railswhat else has to be fabricated to swap onto an 87 tpi car im thinking of buying one thanks chris
Quote:
Fuel lines. Not sure what waterneck guys are using. Originally Posted by mrestrictrplate
besides fuel railswhat else has to be fabricated to swap onto an 87 tpi car im thinking of buying one thanks chris Figure another $150 or so.
I wish the chinese would knock off the proflo xt manifold.
-- Joe
mrestrictrplate
close
im saying what needs to be done to make it work w throttle cable kickdown, sensors and will it work w the factory mass air computer thanks Chris
Quote:
Same as the HSR. This might be a little beyond your ability. Might want to read more.Originally Posted by mrestrictrplate
im saying what needs to be done to make it work w throttle cable kickdown, sensors and will it work w the factory mass air computer thanks Chris -- Joe
project89
close
-- Joe
Originally Posted by anesthes
Fuel lines. Not sure what waterneck guys are using. Figure another $150 or so.
-- Joe
im using one of a factory 327 engine that i had laying around
I just ordered this "HSR" as well. was uncertain which route to take with my 87 lb9, but this seems to take the cake by using the stock throttle body.
Quote:
For the money, assuming you bought the $200 chinese one it's a good deal. Originally Posted by big hammer
I just ordered this "HSR" as well. was uncertain which route to take with my 87 lb9, but this seems to take the cake by using the stock throttle body. -- Joe
Quote:
-- Joe
yup the Chinese one for $200. just need rails and fuel pressure regulator now. if I can find a bigger TB for cheap, I'll get one as well.Originally Posted by anesthes
For the money, assuming you bought the $200 chinese one it's a good deal. -- Joe
