new Chinese 285$ hsr
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: new Chinese 285$ hsr
-- Joe
Car: 2002 ws6, 2011 sierra 6.2L 6 speed
Engine: ls1
Transmission: M6
Axle/Gears: 3:42's
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Yep.. Some might argue that folks are trying to forget the TPI/LT1 stuff as if it never existed.
That's why I mentioned earlier, I wish the chinese would knock off the pro-flo XT intake. For folks that one a horizontal draw SBC it's the way to go. Up to a 105mm LS2 style throttle body makes it a safe bet for a boosted motor.
My next build will probably be a 6.0 though. That stuff is just too cheap now, makes soo much power effortlessly.
-- Joe
-- Joe
Engine: ls1
Transmission: M6
Axle/Gears: 3:42's
-- Joe
-- Joe
a cheap proflo would be nice.
is it an option to use an LT1 TB on an hsr?
http://www.ebay.com/itm/Accel-Lingenfelter-58-mm-TPI-fuel-injection-throttle-body-1000-HP-Camaro-Vette-/311146525411?pt=Race_Car_Parts&hash=item4871c732e3&vxp=mtr
Car: 83 Z28
Engine: 355 SBC
Axle/Gears: 3.90
Have you confirmed that the plemum will clear a stock hood? I am considering buying one but want to keep the stock hood.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Worst case scenario you trim the hood support a hair. I had to do that on my formula hood to clear my elbow.
-- Joe
it cleared my factory 89 iroc hood ,
would not clear my amd steel 4 inch cowl due to the built in air cleaner box
Engine: ls1
Transmission: M6
Axle/Gears: 3:42's
looking for cheap fuel rail alternatives to the holley kit. but by the time you piece together the rails, lines and regulator, there's not a pile of savings.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
The Chinese fuel rail kit is $60
http://www.ebay.com/itm/SMALL-BLOCK-CHEVY-ANODIZED-RED-BILLET-FUEL-RAILS-W-FITTINGS-SBC-/131318546113?pt=Motors_Car_Truck_Parts_Accessories&hash=item1e9331fec1&vxp=mtr
And then a regulator is anywhere between $46 and $130 depending on what brand you get (pro products, aeromotive, etc) .
So let's say you went all out, that's what $390 for the "chinese" HSR complete with fuel rails and -6AN fittings
A HSR (satin, not polished) is $366 and the fuel rail/reg kit is $268
Thats $634 for the HSR, $244 more than the chinese version. And again, that is assuming you go with the more expensive regulators.
-- Joe
Car: 1991 FORMULA
Engine: ZZ4 + LT4 HT CAM 430HP
Transmission: 700-R4 COMING T56
Axle/Gears: 9" 4.56's (COMING)
What ever happened to the new block they came out with that accepted stock sbc parts but takes ls1 top end stuff?
Car: 1989 RS Camaro
Axle/Gears: 3.73 Posi
Project89 or anyone else were you able to do a comparison of the Holley plenum on the Chinese base? I have the Holley HSR but I have a set of vortec heads I'm going to use and I know they have the chinese vortec base available so is it possible that the Holley plenum bolts to the pro comp base? Or does it require modifications. I emailed pro comp/ speedmaster about this and couldn't get an answer other than
"Sorry sir I am unsure of the Holley manifold will bolt up to our lower.
Speedmaster79"
Thanks in advance guys for the help.
Speedmaster79"
Speedmaster79"
Speedmaster79"
i never even though about checking when i had both , but they should be the same
but why wouldnt u just buy the complete vortec one base/plenum for 200 bucks instead of just the base
Car: 1989 RS Camaro
I picked up the complete Holley for $200 already and was wanting to get the weiand/ holley vortec base but can't find any dealer that will separate it. I guess I could just get the other set up but I figured I'd save a little money where I could and I didn't know if anyone had tried it. It's worth a shot. Then I wouldn't have to worry about holley fuel rails not lining up on the procomp set up. Just thought I'd ask and then we'd have some more info on these for the next person.
Car: 1985 Pontiac Trans Am
Engine: 6.6 Liter 406 c.i.
Transmission: T-56 6 Speed/ McLeod Street Twin
Axle/Gears: 3.42 9 Bolt Posi w/ girdle
Project, I've got a legit HSR on my 406, and was worried about porting it to match my Bowtie Phase II heads, as the material is kinda thin. Also, have you gotten yours running? A big issue with the original HSR's (bought mine in 2004) was that they leaked oil since the head side was machined uneven. Does the Chinese version have this issue too? I "fixed" mine by running a 1245 gasket instead of the usual 1206. If you happen to have any base intakes laying around already ported (my porting skills are still developing) I'll gladly purchase it from you.
im running mine with set of assualt 200cc aluminum heads which are basically dart pro 1 platniums
Engine: ls1
Transmission: M6
Axle/Gears: 3:42's
Car: 87 Iroc
Engine: modified 350
Transmission: high performance built 700R4
Axle/Gears: Strange S60 3:73
Looks like a quality piece.How do I get it to fit under a stock hood?I would also like to hear more about the Assault 200cc heads.Thanks
Engine: ls1
Transmission: M6
Axle/Gears: 3:42's
supposed to clear a camaro hood, and supposed to clear a firebird with some notching on the hood framing.
Car: 87 Iroc
Thanks for the info.I am really interested in these and the Chinese Stealth ram.
Car: 83 Z28
Engine: 355 SBC
Axle/Gears: 3.90
I received mine and was very impressed. I am not working on gathing everything else to convert my 83 to TPI. The winter project has begun.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I'd buy one if I could mount a LS2 throttle body to it. I wish they made two different lids.
I suspect I could cut and weld a LS2 flange on the lid, but by the time I'm done might as well bought a pro-fo XT or ramjet eh?
-- Joe
-- Joe
ditch the 305 , get a jy vortec shortblock from the jy or a tbi truck motor withthe small chamber tbi heads , slap a set of the assualt heads and ching chong hsr and boost the hell out of it
both of those jy motors should have the dished pistons from the factory
for about a grand u have one very capable n/a 350 , then u add the turbo and the fun really starts
Car: 87 Iroc
Hi Anesthes, what else besides the pressure regulator would I need to hookup those fuel rails to the Stealth Ram ?Thanks,Steve
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I normally use something like this:
http://www.summitracing.com/parts/rus-640830/overview/
Then make up a short run of braided -6 line to the rail.
One for feed, one for return.
-- Joe
Some adapters to adapt your factory fuel lines to -6AN. Some years had two 16mm saginaw (o-ring) fuel fittings, others had a 16MM and a 14MM. Figure out what you have and then order appropriately from summit. Russel, earls, even summit house brand make 'em.
-- Joe
-- Joe
goto napa and have them make u hydralic hoses
for the feeed u can have them make a hose with a jic -6 female on one and and a hose to 3/8s hardline adapter ( compression fitting) on the other
then u just cut the stupid metric fitting off the factory feedline and install the hose
total cost on the fuel feedline is 23-32 bucks total , the hydralic hose is basically steel braided line with a ruber coating over the steel braid and its rated to a much higher presure then standard braided or pushloc hose
u can also have them make the return line , i didnt bother cause i had enough pushloc hose to make the line fromthe rail to the regulator , and then i just used barbed fittings from the regulator back to the factory return line and used standard fuel injection hose and hose clamped it since there is minimal presure from the regulator back tot he tank/factory hardline
when i asked them the price for doing aline for my new fuel pump it was 100 bucks for 25 ft of 1/2 inch id hose with 2 -10 ends i ust gave them the 25ft number to get a general estimate ont he price i wont need anywere near that much hose to from the pump to the engine
The plenum is a simple box, so fab your own with whatever TB flange you want
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
no need for all that
-- Joe
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
-- Joe
i was told it was rated for gasoline and diesel , friend uses it on the farm on alo tof there equipment has been for years with mostly diesel fuel and has never had an issue
the hose comes in parker and gates , they even have it with ptfe liner
basically this is it
http://www.napaonline.com/Catalog/Ca...508_0215881806
check with ur local store for the brand they carry and its ratings as they do vary browse napaonline.com for hydraulic hose and u will see all the different types
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
I wish I could've used the one I bought and ported, my 91 got rearended so I no longer have use for it.
Car: 92 rs z28 clone
Engine: forged 350
Transmission: 700r4 fully built
Axle/Gears: moser axles eaton posi 3.73 gears
Hey project can you or anyone else tell me what the size and thread is for the vac. holes in the back of the plenum I bought one a few months ago ported it and its on my new setup but the brass barb fittings that I have used in the hsr in the past wont fit this one its a different thread.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
-- Joe
but i dont belibe steel braided line or pushloc is either
I'm sorry that happened to you. A few years ago I had to put a whole new front end on my car when a soccer mom in a Lexus SUV cut me off in the rain and jammed on her brakes. Then she gets out of her SUV, still on her phone, and yells at me for it. Is your damage repairable?
The whole body was tweaked and since my insurance won't cover it I'm having to part out whats left
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
but u have a v8 car its abolt in deal why even bother when u can make a ton more power , then again i guess with the 8 second ride of urs u dont need another one thats a rocket
if u lived closer would be badass to line urs and mine up one day, mines getting alot of upgrades this winter , wifes starting to yell at me.This week alone ive filled the living room up with an 8.8 rear a entire new fuel system, wheels and tires, parachute, and a bunch of other lil stuff
Project, how did you solve the ECM temp sensor issue? I was thinking an adapter would suit the purpose maybe if you cut a few threads off? I'm going to be buying one of these and that's my last hanging point. Everything else from my original SR I'll just swap over.
Car: 89 Iroc-z
Transmission: TH400
i just dont see the point , yeah yeah i know im the guys withthe high powered v6,s but those cars were v6 cars to start lot of work to swap in the v8.
You were out in johnstown area at one time right? Sucks my car wasnt together then, it would have been nice seeing another turbo thirdgen
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Do you guys think it would be too difficult to make an adapter to run a LS2 throttle body (4 bolt) on a chinese stealth ram ?
I kind of want to mount my throttle body facing forward for plumbing reasons but if I do I'll need a new hood. (need 10" in the front of the block). If I go to a lower profile elbow, I'll have to run a remote thermostat. (and the elbow might flow horrible).
-- Joe
-- Joe
Car: 1991 firebird
Engine: TBI 305 (built)
Axle/Gears: 4.10
