Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Pro flo xt help!
Old Apr 5, 2014 | 11:45 AM
TAmaniac's Avatar
Car: 85 Trans Am
Axle/Gears: 342
Pro flo xt help!
Does anyone know anything about the Pro Flo XT System. I have installed the setup in my 85 Trans Am with a 355 engine. The setup came with complete wiring harness ecu, etc. Everything works and powers on but I'm not getting spark or injector pulse. I have triple checked timing, distributor setting. From what I can tell the ecu is supposed to ground the coil? I have 12v on positive and neg. side of coil in key on and start positions. Also I have 12v to injectors but nothing on the other pin. Not sure if there is supposed to be 12v on both injector pins, ground on one 12v on the other or ecu pulses the other terminal. Please help!
Old Jun 9, 2014 | 11:12 PM
92rsvortec350's Avatar
Car: 92 rs z28 clone
Engine: forged 350
Transmission: 700r4 fully built
Axle/Gears: moser axles eaton posi 3.73 gears
Re: Pro flo xt help!
check your pick up coil in the distributor that's what happens when its bad.
tmellott89
Oct 14, 2015 02:06 PM
djmarch
Oct 2, 2015 10:41 PM
MitcherNeaf
Sep 24, 2015 09:23 PM
italiano67
Sep 22, 2015 08:42 AM
jbates346
Sep 22, 2015 05:22 AM
