Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Remote Mount EGR for the MiniRam II ?
Old 07-14-2014, 07:10 AM
BWilcox's Avatar
Car: 87 IROC
Engine: 420 EFI
Transmission: TKO500
Axle/Gears: Moser 9" 3:50
Hi Guys,
I am presently plumbing my new motor.
I do not need to pass a sniffer test. Hoever, I need to pass a visual.
Unfortunately, i do not have space for the TPIS EGR kit. The valve covers are too big for the kit to fit.
So, the idea is to build a remote EGR system.
I guess someone has been down this path before?
Suggestions?
1.
Should I chassis mount the valve and then use flexible SS Gas tube as couplers to the engine EGR hardline?
Similar to a 4th Gen with the LS.
2.
Other ideas?
Best Regards,
Bruce
Old 07-17-2014, 09:13 AM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Re: Remote Mount EGR for the MiniRam II ?
Do your local smog laws allow moving the egr?
Old 07-17-2014, 11:26 AM
BWilcox's Avatar
Car: 87 IROC
Engine: 420 EFI
To my knowledge, the laws do not stipulate where the EGR valve is located.
I am thinking about creating an EGR valve block that is mounted over the cylinder #8 primary tube. The EGR input would come from the #6 primary. The EGR output would then route over the valve cover to the MiniRam II vacuum port. This solves a bunch of problems in routing hot tubes around the ECM harness.
Just to pass a visual.
However, the EGR plumbing is capable of full functionality.
Alternative ideas?
Best Regards,
Bruce
Old 04-29-2018, 09:02 PM
Duane's 91 Z/28's Avatar
Car: 1991 red Z/28
Transmission: T5 swap
Did you ever get your egr figured out?
tglennon11
09-23-2015 05:30 PM
FormulasOnly
09-06-2015 10:42 AM
SG91camaro
09-05-2015 10:27 PM
rjcme
09-05-2015 01:23 PM
IROCZDAVE (88-L98)
09-02-2015 08:49 AM
Quick Reply: Remote Mount EGR for the MiniRam II ?
