Aluminum heads and single plane...
Just getting around to putting on a set of RHS 12055 aluminum heads on a 89 roller block. Went to put on a motown intake and there was excessive room side to side. Guess I need intake adapters? Anyone else have this problem with these or similar heads?
Car: '87 GTA Black/Black/Gold & others
Engine: TPI 350" & others
Transmission: Many
Axle/Gears: Many
Re: Aluminum heads and single plane...
. Is that a Made in China intake? Could be the problem... regular intake to head gaskets don't fill the space?
. Does your block have dowel pins to hold the heads in their proper location?
. Did a previous or return owner have the intake milled to fit a milled block?
. Heads vs Intake... one Vortec and other Gen.1...?
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
No experience with that intake but I have RHS 220cc based castings and my victor E edelbrock fits fine. On some excessively milled setups, i have seen guys use double intake gaskets. Just use RightStuff in between layers around all ports for best seal.
Transmission: Many
Axle/Gears: Many
. Friend of mine got a Weiand intake made in China and it wouldn't bolt on, hit the thermostat housing, he sent it back, they said didn't realize the drop shipper was getting those now, and they found a NOS one for him of same part number still made in USA and sent it out to him... it worked fine... they looked very different...
Think they might be setup for a raised block and not a standard block so just gonna get some aluminum stock and make some spacers for $30. Instead of spending $170 for a made set.
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Car: 86 iroc, 02 v6 camaro
Engine: 350 HSR, 3800 V6
Transmission: T56, WCT5
Axle/Gears: 9in 4.11 posi, 3.23 LSD
i had to get my HSR intake milled to fit my RHS 200/64cc alum heads. the intake bolts for my head were actually drilled wrong too between the heads.... not happy with RHS/comp performance group in this instance but we made it work.
block was stock, non-decked heads were factory as well
Car: 92 rs z28 clone
Engine: forged 350
Transmission: 700r4 fully built
Axle/Gears: moser axles eaton posi 3.73 gears
fel pro 1266 intake gaskets have worked for me in the past for that.
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
Ither HOT ROD or CAR CRAFT did an article on knock offs and they gave some examples that stood out the most in the market place like the MSD 6AL boxes.
Sent from my iPhone using IB AutoGroup
Transmission: Many
Axle/Gears: Many
. Yeah, somebody posted a picture of a ProComp or somebody's ignition box that looked like an MSD on the outside and all it had in it was a semi-circular electronic unit of some kind obviously out of some brand of distributor... MSD successfully sued them...
ambainb
Apr 25, 2016 09:21 PM
