Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
cam for hsr
Old Jan 10, 2015 | 05:27 PM
bull600's Avatar
Car: chevelle
Engine: 350 tpi
Axle/Gears: 3.55 12 bolt
cam for hsr
I have a roller 355 with a set of flat tops and a hsr with a set of vortex maxx heads 2.02 valves 64cc flow 250 cfm at 500 exhaust is flowtek headers with 2.5 flowmasters my computer is a 411 ecm with no emission stuff my trans is a 700r4 and 3.55 gears in the rear the car will be a weekend cruiser i have been thinking about a comp 276 does that sound about right?
Old Jan 11, 2015 | 12:48 PM
soarestransam's Avatar
Car: 1988 Gta trans am
Engine: LR4 4.8
Transmission: 98-02 t56 6 speed
Axle/Gears: Bw 9 bolt (3.70’s) pbr rotors
Re: cam for hsr
Good cam for the hsr setup are the comp cam exetreme energy cam dont know the actual part number but they are all computer controlled and have a lsa of 114-116
Old Jan 28, 2015 | 08:11 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: cam for hsr
Xe276hr would work. Assuming hyd roller block
Old Feb 18, 2015 | 04:28 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Re: cam for hsr
I had the 276HR on a 110 LSA in the L98 with a HSR intake and AFR 195's. Pulled to 6k all day. Was a nice setup.
Old Feb 19, 2015 | 08:02 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: cam for hsr
I ran the LT4 hot cam in a 355 with trick flow heads , flat tops and a single plane. Made 320 hp on a mustang dyno with a conservative safe tune. I think the XE276HR is a good choice, better than the hot cam. Idle was noticed but not unruly or really lumpy.
Jorlain
Oct 8, 2015 01:57 AM
86CamaroDan
Sep 29, 2015 10:08 PM
355tpipickup
Sep 4, 2015 05:32 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
