Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Installing vortec HSR on zz4 heads?
Old Mar 25, 2020 | 08:47 PM
vasquezmrysvll's Avatar
Car: 1985 California Iroc
Engine: HSR ZZ4 0411 swapped
Axle/Gears: 3.23 posi
Can this be done? Can I simply drill new holes in the intake flanges? Has anyone performed this task, or should I continue to look for someone to swap me bases? Thanks
Old Mar 26, 2020 | 07:31 PM
Larry's Avatar
Car: 86 Corvette
Re: Installing vortec HSR on zz4 heads?
You could use a gasket to see if the ports will line up close enough but usually vortecs and standard intake patterns wont work without welding and machining. It would probable be better to just find the correct manifold.
Old Mar 26, 2020 | 09:06 PM
I made a template out of 2” masking tape and cardboard (felpro 1255’s are a week out) this actually seems pretty easy and very do-able. When the gaskets come in I’ll confirm my measurements, I’m just wondering if anyone else has tried this. For the price I got the HSR for, I think I’ll take my chances. Thanks for the reply!!!
Old Mar 31, 2020 | 04:06 PM
85Z28NOS's Avatar
Car: 85 Camaro
Engine: 454 RamJet
Transmission: LT1/T56
Axle/Gears: 8.8w/4.10
Knowing that the vortec base is now obsolete I would simply buy the 7540 base or sell your current one to cover the cost of the correct one.
racingdragracer
Feb 1, 2017 05:57 PM
conlinj
Jan 18, 2013 04:48 AM
RevItUpZ28
Sep 6, 2007 12:39 AM
CHEVY_EATER
Mar 9, 2005 11:05 AM
88 350 tpi formula
Nov 11, 2003 01:57 AM
