Sniper EFI
Sniper EFI
I am going to install a sniper EFI system this winter and I was looking to get some advice on the fuel system..
My car was a factory L69 84 TA it is running a mechanical pump from the previous owner on a carbed 350. It looks like I have 3 options
1. Run the external pump with the holley kit
2. Sump under the hood
3. intake pump
I have figured out the first two options does anyone have any advice on the 3rd? Is there a setup that is easy to install in our tanks?
Any advice from anyone who has done it?
3. intake pump
Re: Sniper EFI
For sure go with the in tank pump, I run a walbro 255 lph , make sure you change the return line size to 3/8 it needs to be same or larger than feed line. The external pumps are nothing but problems with the Sniper.
Re: Sniper EFI
Would my best bet be to get a 92 camaro setup like this, add the 255 pump and then deal with the fuel lines?
Re: Sniper EFI
Would it be better to use the holley in tank setup?
https://www.holley.com/products/fuel...parts/550-510D
Re: Sniper EFI
These Sniper's are getting more and more popular. I have an intank setup out of an '92 Z28 that I flared for fittings. I would run that with a universal AEM pump, then would just worry about the feed and return lines being accurate in size on your '84, and just correct for if they are smaller...
- Rob
- Rob
Re: Sniper EFI
Yes exactly, I have a 91 which uses that same one , then there is some cutting and reconfiguring of the tubes, but fairly easy to do you will also need a 10 micron inline filter , watch this video he shows you how to do it .you tube by klowny 69
Car: 1987 IROC-Z
Engine: 406 on N20 w/ EFI
Transmission: P.B. 700R4
Axle/Gears: 12 bolt w/ 3.91
Re: Sniper EFI
I run the sniper TBI efi and fortunately my car was an in-tank pump from the beginning. however I run a racetronix hotwire kit, with racetronix relay, and the racetronix in-tank wiring upgrade too. I did NOT use the holey sniper efi fuel system relay. I run a racetronix 340lph pump and a 10 micron filter on a -8 ptfe feed line and a -6 return line. never had a fuel system issue aside form I was not venting the tank pressure properly by crimping closed the vent port tube that used to go to the charcoal canister. I ended up putting a small breather filter on it (while also keeping the factory oem acorn rollover vent valve) and I have not had any issues since then. I would opt for an IN-TANK pump . As has been mentioned, sniper systems are sensitive and in tank pumps with proper psi are required. I am a big fan of the sniper and its basic features/tunability along with the datalogging.
IROC YA (05-26-2023)
Re: Sniper EFI
Do you guys see any issues with using my stock 84 tank besides needing the TPI pickup and lines? Are there differences in the fuel sender or tank I need to be aware of?
Re: Sniper EFI
Pretty sure the sender opening and tank depth etc. are the same, just make sure it is clean
Re: Sniper EFI
Thanks I made a list of all the parts / adapters I think I will need to get it done. I will start ordering and probably start after the new year.
Re: Sniper EFI
The system is at my house, hoping to start work on the car this week.
For the tach did you guys use the brown wire from the sniper harness? Or did you go negative coil?
I have the MSD filter in place now and I am using a MSD SS coil with pro billet distributor
Also any suggestions for switched 12V in the engine bay?
Car: 1987 IROC-Z
Re: Sniper EFI
If I remember correctly, i used the brown sniper wire for the tach on the dashboard. for my aftermarket shift light I think I tapped into it. I actually can not remember
Re: Sniper EFI
Thanks I will give that a shot. Hopefully in the next couple weeks I will have it installed but probably wont drive until april ish
Re: Sniper EFI
Small update I got the fuel system done and plumed. It holds pressure between 58-60 psi and no leaks. When I get it all installed I will make a build thread with observations on how I did it.
Re: Sniper EFI
Interested in your overall experience as I'm also looking at getting this kit and converting back to fuel injection. Please keep the updates coming!
Re: Sniper EFI
The plan is this Saturday get the wiring done. For now I am going to leave the distributor regular mechanical advance. Later after I know the rest is good I will try to control my ignition.
I need to
1. Install the sensors (O2 and temp) and wire them up
2. Run wires for the fuel pump using the factory bulkhead and plugs
3. Wire distributor and ignition Coil
4. wire power and grounds.
Mechanical items are bolted in place and the throttle cable is in place but I will probably play with the adjustment later.
I need to
Car: 1987 IROC-Z
Re: Sniper EFI
that is exactly what I did with my setup... I left the timing control to the mechanical advance of the MSD 85551 distributor for a few weeks. Once I established that the engine and everything connected to it was working good, I converted timing control over to the sniper but still using the msd distributor (locked out). A few months later, I went for full blown timing control and got the holley hyperspark ignition system and everything works together seamlessly.
Re: Sniper EFI
Its alive. The walboro 255 is working great. No leaks on any of the fittings and it started and ran perfectly. It idles about 850 rpm now which is my set point and the fans turn on at a perfect 210F and off at 195. The wiring is ugly right now so next couple weekends will be about cleaning it all up and then putting the interior back together. I could not be happier. When I get it all done I will make a post with PNs and some how to information.
The following 2 users liked this post by midias:
NoEmissions84TA (05-26-2023), Street Lethal (02-07-2021)
Car: 1987 IROC-Z
Re: Sniper EFI
cool. there is a bunch of stuff you can do with the sniper handheld, but LOTS more you can do with a laptop. so, keep in mind that if you get the Y-splitter and CAN-BUS cable you can tune in real time.
Re: Sniper EFI
Awesome I did not know. I will have to get one in the spring. It is about 10F outsife now and snowy so I have plenty of time to get the car back to normal before I start driving.
Car: 1987 IROC-Z
Re: Sniper EFI
exactly! I was in the same situation as you are just last February. I took it one step at a time . Enjoy. Datalogging and examining the datalogs is super fun too.
Re: Sniper EFI
I know it is controversial but I cut a fuel pump access hole. Then I used m6 nutserts and bolted on a new cover. I'm going to use some gas proof sealer similar to what Honda does for their cover between the two panels when I button it all up.
Re: Sniper EFI
I'm following because I also have an 84.
Re: Sniper EFI
We finally had some decent weather for one week and I got to drive the car. First impressions are this system is great with a couple small issues
First drive impressions
1. Self learning was fast for the first 20 minutes I would get some stumbles when doing some light throttle and then heavy throttle. They smoothed out quickly and after 45 minutes the car felt great
2. Throttle is touchy way too touchy with stock linkage it was everything I could do to not burn out in 1st gear (5 speed) autos may be better
3. Pick up after self tuning is awesome and instant with very little throttle
Post 1st Drive
1. Progressive linkage ($14) is a must for me I installed it so first 2 throttle plates open then at 40% other two open. Starts are much easier and car is much more drivable I did have to bend the linkage a little to make it a perfect 40%
2. With progressive linkage pedal felt way to light added a weak throttle return spring to make it feel normal.
3. Hot and cold starting the car is causing the system to go super rich and stall the car. I believe this is because the new tune values in the table.
4. 15% fuel removed across all coolant temp values for after start enrichment. Hot and cold starts are much better but getting a lean spike.
5. 6% fuel added back in to all CTS values for after start enrichment. Will test today but hot start yesterday was perfect.
Other impressions
1. Hand held tuning is easy to use and intuitive (can't wait to try laptop)
2. System is going a good job maintaining A/F ratios on idle, cruise and acceleration
3. Car has never been so smooth or drivable even after tuning the carb with a A/F gauge and vacuum gauge.
4. Idle is smoother than ever across all temp ranges
5. Fan control is working perfect with my settings 210 on 195 off
6. Car is making more power for sure at least in the mid range
7. I can drive immediately after starting the car cold with no coughs or stumbles edelbrock never did that
Overall it is worth the time and effort. A little more tuning will fix the hard start issue and the way it drives makes the car feel 20 years newer.
Post 1st Drive
Other impressions
IROCZman15 (03-12-2021), NoEmissions84TA (03-12-2021)
Car: 1987 IROC-Z
Re: Sniper EFI
glad you like it. there is a lot to learn and get used to, but as you said, it is a great system. keep us posted. Its been a few months since I have needed to re-visit the car's tuning but now that spring is upon us, i will be getting back to it soon. im glad you are enjoying it though. keep us updated, you seem to be getting into it all pretty well. !
Re: Sniper EFI
Saturday I put a larger charging cable from the alternator back to the battery to compliment the new alternator (63A to 94A) and I also used a relay to isolate the +12V ignition to the EFI system now the 12V_IGN line just triggers the coil on the relay and then clean battery power feeds the Sniper unit. I was not having issues this was for peace of mind knowing my +12V_IGN also fed the ignition coil I wanted to isolate it. I still have a little wiring to clean up but so far so good.
Unfortunately my radiator started to leak so a new one is on order. Cooling system should be good ,new Dual fans, HD water pump, hoses, overflow bottle and radiator. Before the leak cruising temp per the ECU was 178 - 183
A couple suggestions for removing EMI / RF from sniper.
1. Use spiral spark plug wires
2. use resistor plugs
3. New cap and rotor
4. Run signal wires separate from power and ignition
5. Isolate 12V_IGN
5. Isolate 12V_IGN
NoEmissions84TA (03-15-2021)
Re: Sniper EFI
I did not know for sure I had a small pump in my tank so I bought a new TPI pickup ahead of time on RockAuto for $55. The Walboro 255 lph pump I used was much taller than the small helper pump and I think the factory TPI pump is also taller. You could probably make it work as long as you had the plug to go into the pump and cut the metal tube a little bit to accommodate the taller pump.
Re: Sniper EFI
Car: 1987 IROC-Z
Re: Sniper EFI
no, this sniper system has no provision for a knock sensor. unfortunately you would need to step up to one of the more advanced EFi systems.
TGO Supporter/Moderator
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, 355" LT1, LT1
Transmission: T5, Zf6, 4L60E
Axle/Gears: 3.42, Dana44 3.45, 3.23
Re: Sniper EFI
Heck, GM had to desensitize the LT4 knock module back in the day to prevent it from retarding timing too much under load.
-- Joe
NoEmissions84TA (04-17-2021)
Re: Sniper EFI
Installed some 1.6 ratio rockers this week after a couple drives the sniper system seems to be getting happy again. It is fun watching the learn table and seeing what compensation the system is making vs the previous setup. Unfortunately snow is back today so no more driving for a bit. I still need to make a thread for install
Car: 2 camaros, 1992 v6 /1984 350
Engine: 350 with holly carb swap to sniper
Transmission: Both are auto 700r4 both 1992
Axle/Gears: unknown
Re: Sniper EFI
Hey man, did you use the holley 10 pin extra connecter for your AC relay? I did and now the compressor wont turn on, anyone have any tips??
Re: Sniper EFI
Re: Sniper EFI
Do you happen to know the part numbers that you used from Racetronix ?How did you modify the pump hanger for -8 and -6 as well ? What breather did you use on the evap line? I am having the tank pressure issue and can not figure out why. Washed out hte oil twice just parked in the garage. Thanks in advance.
Starting to put together my stealth terminator set up, once they are back in stock.
Car: 1987 IROC-Z
Re: Sniper EFI
@IROCZman15
I can dig up the parts list out of the file caboinet, but cant get to it today. remind me, and I can get it for you.
Here is a link to the online photo album where I stored the photos I took of the fuel system upgrade.
photos in the album of stuff I did back in 2016 or so
Re: Sniper EFI
@IROCZman15
Yeah if you wouldn't mind digging those numbers or list up I'd appreciate it !
I tried to get numbers from the pic but they are just not quite legible.
Did you do -8 feed and -6 return ?
Where n NJ r u ? I'm in delco PA
Thanks in advance !!
Car: 1989 Trans Am
Engine: sp357
Re: Sniper EFI
@IROCZman15
https://aeromotiveinc.com/product/fu...ro-200-340lph/
#42
Car: 1987 IROC-Z
Re: Sniper EFI
WildCard60: I remember thinking that same exact thing both before starting my fuel system research, and while putting it all together. I remember asking either here on TGo or another tech forum about it, and I think somehow the consensus was that, that short amount of 3/8" line in the hat was not enough length to be an issue. I don't remember the details, but someone made some valid points about it. However, if it is scientifically provable that it would be a restriction if that 10" section of factory 3/8" line is hindering a the realistic use of the rest of the -8 feed line all the way up the underside of the car...well I would like to know for sure.
DaVinci: Sure, I will have to dig them up. send me a PM about it and that way I will be sure to see it and I will reply to you or to here with the stuff I ordered (fyi, i went overkill and got multiple extra fittings, hose, tools, and whatnot because I knew that my first several attempts at building PTFE -an hoses was going to take some practice. I can try to get that paperwork for you tomrrow.
#43
Car: 1987 IROC-Z
Re: Sniper EFI
I found the invoice. Sorry it took a few days. I over-ordered what I needed to buy on purpose. All of the system I put on is still on the car to this very day, and has held up exceptionally well. In fact I just checked the fuel filter (inside the billet case) last weekend, and it came apart easy, was clean, and reinstalled perfectly.
Here is the photos of the invoice.
Davinci50 (05-31-2023)
#44
Re: Sniper EFI
Doing an experiment on the sniper linkage system. I ditched the progressive linkage where 2 throttle bodies opened until 40% and then the other 2 snapped open. I modded a Holley throttle extension arm for the cable and switched the linkage to all 4 throttle bodies opening at the same time. The extension gives me more control from leverage and all 4 gives opening at the same time give me a smoother power band. Its weird to drive the big throttle kick at the transition is gone it just revs smooth, the low speed throttle response is also great. I made the swap because I was getting an issue with low throttle some times the car felt starved for air. Had to kink the extension a bit to clear the air cleaner
#45
Re: Sniper EFI
I don't know, but might this have accomplished the same thing?
Quick Fuel 43-4QFT LINKAGE KIT (4150) SUPER PROGRESSIVE & 1:1 (holley.com)
#46
Re: Sniper EFI
NoEmissions84TA (06-30-2023)
#47
Re: Sniper EFI
Loving my sniper EFI still no problems. This winter I'm doing the sniper distributor.
DynoDave43 (11-15-2023)
#48
Axle/Gears: 10 Bolt 2.73 Open
Re: Sniper EFI
The new Sniper II has some additional outputs...I'm hoping one might be used to control TCC lockup, but I've got to do a little more digging on that. I want to be able to control / set the parameters that trigger it.
#49
Car: 1990 GTA
Engine: stock L98(being pulled for rebuild)
Transmission: stock 700R4
Re: Sniper EFI
I'm strongly considering the Sniper setup for my upcoming engine build. What advantage does the Hyperspark give you if you already have your Sniper up and running?
#50
Re: Sniper EFI
More accurate timing control and the ability to change your timing curve with a laptop. You can also tune a lot better and theoretically gain more horsepower and better gas mileage. In the spring I'll let you guys know how I like the new distributor
GTA90X (02-06-2024)
