Post your tips and tricks
Old Apr 16, 2002 | 11:35 PM
86FyrBrd's Avatar
Car: 1992 Camaro Z28 Convertible Z03
Engine: 383 SuperRam
lets see what you guys do, have any methods you like for anything to make your car look better, things you'll do before a show... anything. post it
Hidden Water- Use an air compress to blow it out, small areas you can even use the aerosol computer duster can things
Wheel wells- Armoral, Black Spray Paint, or undercoating
Trim- if its old tape of your car/windows sand down and re-paint the metal trim around your back window flat black and also the stip between your t-tops
weather stripping- armor all it, makes it last longer and look better
tail lights- dont forget to wax them too
Interior- since it is fairly easy, if your interior is really dirty, go as far as taking out your seats to vacuum, clean, or even dye your carpet clean.
Engine- use armorall on hoses, and anything else plastic or rubber under the hood.
these are all things I have done getting ready for a show in two weeks, how about you guys
Old Apr 17, 2002 | 06:51 AM
Twistopher's Avatar
Car: 91 Z28 Convertible
Engine: 305TPI
which show is coming up? I am in MD.
Old Apr 17, 2002 | 08:01 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Originally posted by Twistopher
I am in MD.
Me too, Me too.
Old Apr 17, 2002 | 09:04 AM
86FyrBrd's Avatar
GM On Display, Macungie, PA April 28th
Old Apr 17, 2002 | 09:32 AM
wiggy'sIROC's Avatar
Car: 1986 IROC
Engine: 305 going to 355
Originally posted by Mark A Shields
Me too, Me too.
Where in MD? I am from Maryland, but I am in the Air Force and moving around, but will be coming back.
Mark
Old Apr 17, 2002 | 09:49 AM
Car: 99 Formula
Axle/Gears: 342
Right now in college I'm at Frostburg, Allegany county, but at home Calvert County, So. MD.
Old Apr 17, 2002 | 10:08 AM
Black85TransAm's Avatar
I am going to take POR-15 to my wheel wells to make them look black .........
2. the same for the underneath my car
Old Apr 17, 2002 | 11:31 AM
mGiTkAe92's Avatar
i havent finished mine just yet have a show the 27th
thnks for the tips i am going under my hood next week to shine it a tad i have used wd40 for those hoses before but found amour all better
where in pa is macungie??
carlisle is having a show this weekend thought about going there but dont know
is por 15 easy to apply??i thought about it before but wasnt too sure....
thanks for the tips tho
Old Apr 17, 2002 | 11:42 AM
86FyrBrd's Avatar
Macungie is basically allentown, its like 5 minutes away.
so Eastern PA
Old Apr 17, 2002 | 03:25 PM
Twistopher's Avatar
Engine: 305TPI
man... i looked it up on mapquest and I am 3 hours away from there. I am itchin for a car show but 3 hours is a bit out of the way... I keep forgetting PA is a huge state. oh well...
Old Apr 17, 2002 | 03:43 PM
Hg's Avatar
Hg
Car: '87 Z
Engine: 355 in the works
I use 'Never-Dull' on the TPI. Try some mothers aluminum polish on your air conditioner condeser I think it is? Or is it the pump? Anyway, the part that is on the passenger side of the engine bay towards the back. Use the neverdull on the metal lines too. Can't think of anything that hasn't been said so far... just look for the little things and take your time.
Old Apr 17, 2002 | 03:57 PM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
Well to stick to the topic a few tips that you might allready know.
1.paint stripper on my rims to shine it up
2.head lights dont pop-up?
>Disassemble the gear box for the head light motor around the triangle gear put 3 peices of plastic strips. reassemble, head lights now move up and down with small bits of plastic
3.worn berring cant find which one?
> place a screw driver on anything that has a pully on it and listen to the end of the screw drive. If its worn you will hear it
4.locked keys in the car?
> Get a 4 1\2 foot rod thats about a quarter inch thick. Bend a slight angle. Put it in at the rear corner or the window and unlock the door.
5 Sitting at a stop light and one of those kazzo exhaust ricers pull up next to you?
>Wait till the light turns green, depress the accelerator and watch him disappear in the rear view mirror
Old Apr 17, 2002 | 04:33 PM
Car: 1986 IROC
I am from Cecil Co.. I grew up going with my brother to the dragstrip before it became "bigtime".
Mark
Old Apr 17, 2002 | 10:00 PM
86IROCZ's Avatar
That's the best tip ever
Old Apr 17, 2002 | 11:30 PM
86FyrBrd's Avatar
One of these kazzo exhaust ricers?
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
mrdevontay
Sep 2, 2015 08:04 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
masonta
Sep 1, 2015 06:40 PM
