Decal install ?
Old Jun 18, 2002 | 09:05 AM
dd85T/A's Avatar
Car: 85 T/A
Decal install ?
I just ordered a set of sail panel bird decals for my 85 T/A. How are decals installed? Thanks for your help.
David
Old Jun 18, 2002 | 11:31 AM
ops32's Avatar
Car: 1983 25th Anny Daytona 500 T/A
Engine: Stock...inoperative... 305
Transmission: Automatic
Re: Decal install ?
David
They're usually just peel-n-stick. If you are concerned about getting them set properly, you can get a cheap spray bottle and mix up a solution of soap and water and mist it on the area where you want the decal to be. Carefully place the decal on top of the misted water/soap area and when you get it set where you want it, use a squeegee to remove the water/soap mixture from under the decal (squeegee over the decal).
Rob
Old Jun 18, 2002 | 12:20 PM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
How much were the decals?
Old Jun 18, 2002 | 01:04 PM
dd85T/A's Avatar
Car: 85 T/A
$18.55 each from Classic Industries.
Old Jun 18, 2002 | 02:03 PM
85 T/A WS6's Avatar
Car: Recaro Option T/A
Engine: 305 Tuned Port Injection
Axle/Gears: 3:27 Borg Warner
Remove all wax in the area with Dawn dish soap.
Use a spray solution of 2 drops dish soap and water, mix in a regular size spray bottle. Spray the application side of the decal with the solution as well as the area to applied.
Locate the decal and adjust as needed. Spray the top of the decal. Now use your squee gee to remove the bubbles, start from the center and work your way out. Its the pressure you apply at this point that makes it stick. Let dry overnight, no peeking until its dry! Have fun
Don
Old Jun 18, 2002 | 03:36 PM
scott's85T/A's Avatar
yep. what he said..I did mine too and it was not a problem at all.
Old Jun 18, 2002 | 03:42 PM
no_car_yet's Avatar
Don
Just a quick question. If i got a car i may get one of those, but what do you think that a black and gold bird would look like on a white GTA. Gold would match the wheels, and the black would contrast well with the white and would match the tinted windows. How do you think it would look??
Old Jun 18, 2002 | 10:02 PM
85 T/A WS6's Avatar
no car,
I think the white and gold combo rocks
Here is a pic of a white recaro option 85 T/A with the gold accents:
Old Jun 18, 2002 | 11:15 PM
socal85tam's Avatar
Car: 1988 IROC-Z
Engine: 383 HSR
Transmission: 4 speed Automatic
Axle/Gears: 4:10
I just got my set of decals and lower body stripe, I think I'll install'em this weekend
Old Jun 19, 2002 | 08:06 AM
85 T/A WS6's Avatar
Right on! Let us know how it goes, get pics !
Don
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
redmaroz
Apr 25, 2017 07:14 AM
ken3983
Aug 23, 2015 07:31 PM
