shaving antenna
Old Jun 19, 2002 | 03:03 PM
logikal6785's Avatar
shaving antenna
what does it take to shave the antenna on an 89 GTA ? i tried to unscrew the telescoping antenna so i could start pulling off the little disc on the fender line but it wouldn't unscrew .... supposedly you have to get INSIDE the fender to rip it out ?!?!
Help!
Old Jun 19, 2002 | 05:27 PM
Bluebird's Avatar
Car: 1991 Pontiac Firebird
Transmission: 700R
Power
Why dont you just put a power antennae in?
Old Jun 19, 2002 | 06:49 PM
Jim 86 Bird's Avatar
Car: '89 TA
Engine: LB9
Transmission: M5
You would want to work on the inside of the fender anyway to properly fill the hole in that the antenna leaves, so why not just get another power antenna?
Sorry if I'm missin' something here
Old Jun 19, 2002 | 07:41 PM
Scott_92RS's Avatar
Car: 1992 RS
Engine: 406 Stealth Ram
The whole point of shaving the antenna is to get rid of it so it doesnt ruin the lines of the car. Replacing the stock antenna with a power one doesnt really do that because you still have a hole and soem kind of plastic bezel around the antenna. I'm not sure EXACTLY how to do it, but it'd probably be best to remove the fender and maybe weld a piece of metal behind it, then fill the rest with bondo and sand it smoothe, then repaint. I've seen/heard about antennas that go around your windshield, but I'm not exactly sure where you would get one. I've heard that they dont get that great of reception, too I guess when I do this I'll just have to burn more CDs Although, by the time I get around to do it, CDs will probably be obsolete, lol.
Old Jun 19, 2002 | 07:47 PM
demon138's Avatar
Car: 89 Pontiac GTA Trans Am
Engine: T.P.I. 383 Stroker
Transmission: Monster 700R4
yeah i have a 89 gta and i had to disconnect it because the motor on it runs for ever. i think it would be bad *** to take it off and fill the hole. oh and with the antenna i cant get any fm channels. what gives.good luck
Old Jun 19, 2002 | 08:36 PM
junkie's Avatar
Car: 84 camaro berlinetta
look close see no antenna all i did was unscrew from top took the plastic in the wheel well out it was just held in by those little plastic clips diconnect the wiring it was power once upon a time then pull it out as for filling the hole ya welding is best but im a cheap bastard so i used fiberglass sheet and filler
Old Jun 20, 2002 | 08:10 AM
Scott_92RS's Avatar
Car: 1992 RS
Not to be rude, but usually people usually use puntuation.
Old Jun 20, 2002 | 10:10 AM
ATOMonkey's Avatar
PunCtuation.
You can buy cheap *** steel mesh with adhesive on it from anywhere glue it to the back side of the fender then fill it in with bondo if you want to do it the elcheapo way.
Old Jun 20, 2002 | 06:12 PM
junkie's Avatar
not to be rude but..puntuation?.....usually people usually use ????
damn sounds like a rap song
Old Jun 21, 2002 | 08:35 AM
Scott_92RS's Avatar
Car: 1992 RS
lol, you got me I swear it was the computer that did it. It knew I was being a little b1tch, so it made me look like one, lol.
Frozer!!!
Jan 19, 2024 04:55 PM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
scottmoyer
Sep 7, 2015 07:06 PM
madsv1000
Aug 20, 2015 06:45 AM
