18" z06 rims on the rear?
Old Jun 24, 2002 | 01:49 PM
camaroguy99's Avatar
ok, so I really wanted the 17x11" zr1 rims but without extensive modification (read: anything but spacers) they won't fit. So I thought maybe the 18x10.5 z06 rims would fit, but it doesn't look like anyone here has tried that. I searched for it, but came up with only a vew people that were thinking about doing it and there wasn't a hrad yes or no. Before I go out and get these things I would like to know with a good amount of certainty they will fit. I plan on putting 285/xx/ZR18's or 295/xx/ZR18's on them. Even if someone who hasn't done this has expience with putting wide rims on the back of thirdgen's I would really appriciate the input.
TIA,
Jim
Old Jun 24, 2002 | 02:45 PM
ImportsRsloths's Avatar
DUDE!!!!!!!! anything from a newer model WONT FIT without an ADAPTER!!!!! Unless you plan on changing your rear, plan on buying adapters!!!!
Old Jun 24, 2002 | 02:47 PM
CustomX's Avatar
Car: 90 irocz
Engine: 350tip
you wil need adapters. and several peopel have the 18x9 1/2 c5 rims on thier car here, but none with the z06. although im saving to put them at all 4 coreners (the 18x 9.5's)
Old Jun 24, 2002 | 02:51 PM
billsfirebird's Avatar
Car: 1984 Pontiac Firebird
Engine: 2.5L Iron Duke 4 cylinder
Transmission: 5 speed manual
This is Third Gen Resource's 91 Z convertible. Are these the Z06 wheels?
Old Jun 24, 2002 | 02:54 PM
CustomX's Avatar
Car: 90 irocz
Engine: 350tip
thats them
Old Jun 24, 2002 | 05:59 PM
ok, maybe you guys misunderstood me, I meant that I will get spacers, I realize that, I just don't want to do fender well modifications. Thanks.
Old Jun 24, 2002 | 07:44 PM
Zirtbow's Avatar
when that car is done it will kick so much a$$.. i could see it now.. imports getting hosed by that thing "oh.. i wasn't really trying.. its a camaro so if I were really into it I would of won"
Old Jun 24, 2002 | 11:15 PM
ttt
Old Jun 25, 2002 | 01:11 AM
sheet outta luck's Avatar
camaroguy99,
with the 295's on the back, they should fit WAY better than the 315's
there are tons of us 4th Gen guys running them
i believe they have the same backspacing as the 11" wide ZR1's(not really positive)
so if they do, the ZR1 spacers should work for your rear
if ya need ta find out the correct backspacing on them, i would recommend asking the guys in the Appearance forum at:
http://www.ls1tech.com
Old Jun 25, 2002 | 02:14 AM
Sho's Avatar
Sho
im getting the same thing i have a hook up on the rims and im getting them cheap hehe about 100 bucks cheaper then the lowest retail price ive seen but u can fit them on without any fenderwell mods but yes u will need the spacers 2 inch for the rear and i believe 2.5 inch in the front...heres a good spacer...spacers . gl
Old Jun 25, 2002 | 11:13 AM
woo hoo, that what I wanted to hear, I'm getting z06 rims!! . Thanks guys.
BTW,
I'm getting a set of 17x9.5's and 18x10.5's for about $1000, sho if you can beat that and are willing to help me out drop me a line and hopefully we can work something out. Thanks.
Old Jun 26, 2002 | 02:26 AM
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
I had to have my mac do a slight wheel well mod because the tires were scraping when I initially put them on. You will probably need some lowering springs as well .
1992rs/ss
16
Jan 28, 2016 09:58 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
zayne0
Aug 24, 2015 07:22 PM
Exxon Limited
Aug 9, 2015 08:13 PM
TMZIrocZ350
Exterior Parts for Sale
Aug 8, 2015 05:55 PM
