factory defect? crack over drivers side window.
Old Jun 29, 2002 | 02:02 PM
camaroguy99's Avatar
Well, I had some body work done a while ago and one of the things I wanted taken care of was this crack over the driver side window. So he fixed and it looked fine for about 6 months. Then it started to come back so I took the car back in because he did a crapy paint job and asked him to fix all the stuff that he didn't do or did a crapy job on before. When I brought up the crack he said that it was a factory defect and because of body flex between the 2 sub frames this crack develops as a result of the torsion forces acting on a weld in that area. Is this true? I hate this crack and it really bugs me because I have to see it every time I get in the car. I do have SFC and I intend to put them on, only there is a conflict with my headers and I need to do some fab work also for them to fit. If I put these on will it fix this problem?
TIA,
Jim
Old Jun 29, 2002 | 02:21 PM
Mirsiro427's Avatar
Sounds to me like he didn't fix the crack properly. Had he welded and stress-relieved the area correctly, it shouldn't have come back so quickly.
Old Jun 29, 2002 | 02:28 PM
Well, this time he welded in a new tab to replace the area rusted out by the crack. How would you go about stress releaving the roof area? There really isn't much you can do up there, that was what I was hoping to accomplish with the SFC.
Old Jun 29, 2002 | 03:13 PM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
SFC's will virtually eliminate the body flex thats causing the stress cracks!
Old Jun 30, 2002 | 09:20 AM
ops32's Avatar
Car: 1983 25th Anny Daytona 500 T/A
Engine: Stock...inoperative... 305
Transmission: Automatic
Re: factory defect? crack over drivers side window.
TIA,
Jim
It's no so much a defect as it is a byproduct of the uni-body flexing. My car has that crack on the pax side. Install your SFCs before you get it "fixed" again, or it'll just reappear. I just installed my SFCs and the car drives like a new car now - no more squeeks & rattles!
Rob
Old Jun 30, 2002 | 03:06 PM
Unfortunatly it's already at the body shop. Do you think it'll be ok if I take it strait from the body shop to the welders? I'll try to baby it over there so I don't put too much stress on it.
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
transaero
Aug 31, 2015 01:14 AM
kyleb24
Aug 15, 2015 08:24 AM
timonator
Aug 11, 2015 09:56 PM
wruiz
Aug 11, 2015 02:59 PM
