will 95 wheels fit on a thirdgen ?
Car: 85&95 Trans am
Engine: 85-LT1 95-LT1
Transmission: 4l60e & 4l60e
Axle/Gears: 3.23 & 3.23
They will fit if you buy some wheel adarters. I believe you need 2.25 for the front and 1.25 for the rear. They won't fit with out buying the adapters. The back spacing is different on 4th gen. wheels than 3rd gen. wheels.
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
Originally posted by 89Irocz23
search button is your friend
Thanks to zepher for the idea, Instead of spending $150 on rear spacers, I spent about $600 on installing mt rear end. Put hay i got pois, better gears and disk brakes, so it was worth it.
kah992
Aug 19, 2015 02:55 PM
