anything i can do for these rims?
Old Jul 27, 2002 | 04:55 PM
TFM4th's Avatar
Car: 87' Firebird
Engine: 2.8L
Transmission: Standard
is there anything i can do for these rims?? or should i just ditch em?
Old Jul 27, 2002 | 04:58 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
The only thing I would do to try and save them for a little while, just spray em all black. But looks like anything else will be a pain in the butt.
Old Jul 27, 2002 | 05:01 PM
TFM4th's Avatar
Car: 87' Firebird
Engine: 2.8L
sorry such bad pics but i wanted them big enough to see so i had to crop them to make the file size smaller
Old Jul 27, 2002 | 05:02 PM
TFM4th's Avatar
Car: 87' Firebird
Engine: 2.8L
i have diffrent rims on my bird right now but i like these better. i was wondering if i could clean these up and swap em on my car
Old Jul 27, 2002 | 05:47 PM
TheLG4Whore's Avatar
Car: '86 Trans Am
Transmission: TH700R-4
Axle/Gears: 10 bolt 3.73
get an aluminum polishing kit and the all mighty Dremel out.:rockon:
Old Jul 27, 2002 | 06:18 PM
Calderone's Avatar
Car: 87 Vette
Engine: 355/195AFR/SR/219CAM/1.6
Transmission: TH700R4/Vigilante
Axle/Gears: D44/3.45
Thats the same way
thats the same way the 16 x 8 of a friend look
what can i do ---if i polish them ..will they look like new ??
my case : https://www.thirdgen.org/techbb2/sho...hreadid=121868
Old Jul 27, 2002 | 06:20 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
They ARE aluminum so they will polish up. It is going to take some real effort and a dremel of some sort but it can be done.
Old Jul 27, 2002 | 06:23 PM
Car: '86 Trans Am
go chechout the eastwood company catalog or go find them on the net they have that ****.
Old Jul 27, 2002 | 07:09 PM
83firebirdS/E's Avatar
Car: 1983 Firebird S/E
I would say that it would be way too much work to get those rims looking nice, because I have polished rims like that before and it is a ton of work! what I would do is check on ebay and you will usually be able to find some really nice ones with tires for around $100.
Old Jul 27, 2002 | 07:11 PM
BirdOfAnother's Avatar
you can go to home depot and for like 12 bucks they have a polishing kit you use in your drill, get some aresol (spelling) and remove the clear coat, the polish the wheels out with teh kit, yeah its alot of work, but boy it looks good
Old Jul 27, 2002 | 07:18 PM
X-treme.92's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
I would just get me some new rims and avoid all that B.S. Sorry thats my 02 cents.
Old Jul 27, 2002 | 09:30 PM
91Zman's Avatar
Car: 1991 Z28
Transmission: 4L60 automatic
Looks like bad clearcoat,a spray can or 2 of aircraft paint remover would take off that old clearcoat.Then just polish the top part and repaint the inner thingies.
Old Jul 27, 2002 | 10:30 PM
I second that.... here is an excellent deal for you:
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1846557070
Old Jul 28, 2002 | 12:06 AM
ops32's Avatar
Car: 1983 25th Anny Daytona 500 T/A
Engine: Stock...inoperative... 305
Transmission: Automatic
looks like it would take a lathe to get those wheels back to half-way decent looking...
Rob
Old Jul 28, 2002 | 08:15 AM
1986redbird's Avatar
mine were not quite as bad as yours but close, heres what I ended up with:
Old Jul 28, 2002 | 12:13 PM
logikal6785's Avatar
what did u wind up with ? wheel weights on the outside ?
hehe jk man those look great i remember seeing before and after pics i think =D
Old Jul 28, 2002 | 12:37 PM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
I know a shop can restore them new . The goal is to do it yourself. Dont use a dremmel unless you want to learn the hard way. What I would do is use some paint stripper on them to get all that damaged clear coat off. Then after blasting off the stripper with a high pressure hose. See if you can polish them up. search this forum on "polish". They cant be that bad I mean its metal all the way through right? So why cant you polish it down to the Good metal under all that clear coat and what ever else that is.
>hack at it!
Old Jul 28, 2002 | 12:45 PM
Engine: 305-4v
Beautiful job! I'm really impressed with the results
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
kitt23
Exterior Parts for Sale
Nov 28, 2015 06:26 PM
dbrochard
Oct 10, 2015 01:03 PM
dbrochard
Oct 10, 2015 01:02 PM
