Bought crystal headlights! need matching fogs!
Old Aug 21, 2002 | 03:43 AM
IROCNParts's Avatar
Car: 1988 IROC-Z Convertible
Engine: 408 Stroker Turbo, TPIS Mini Ram
Transmission: Magnum t-56
Axle/Gears: Ford 9" 3.55
does anyone know where to find a set of crystal foglights.. I bought two sets of the crystal headlights and one set of HALO headlights... I need a set of foglights to match! ... any ideas? thanks
Old Aug 21, 2002 | 06:03 AM
Anth's Iroc's Avatar
Car: 87 IROC-Z
Engine: =350 sbc
Transmission: TH350
http://pages.ebay.com/ebaymotors/browse/Parts.html
Use this link and type 893 you will find the bulbs you need for your fog lights
Old Aug 21, 2002 | 08:29 AM
chevyguy1969's Avatar
Car: 1999 Camaro Z28
Engine: LS1 V8
Transmission: T-56 6spd
DO NOT buy the Eurolite 893's. They say they provide the blue/white light you want but they dont. They are no different than the stock bulbs. Eurolite does have a series called the Xenon Fusion and those are really bluish white but the do not carry the 893's in the Fusion product line.
Old Aug 21, 2002 | 12:58 PM
IROCNParts's Avatar
oh I know where to find the bulbs, im talking about the glass enclosure.
Old Aug 21, 2002 | 04:58 PM
Dave Y's Avatar
Car: 04 Xtreme Blazer
Engine: 4.3L V6
Where did you get the headlights? I whould like some fore my 89 IROC
Old Aug 21, 2002 | 05:32 PM
jocww's Avatar
Car: 84z, 65 elcamino
Engine: l69 and a hyped up sbc in the camino
Transmission: t5 m21
Axle/Gears: 373s 411s
are the headlights that u got any good
Old Aug 21, 2002 | 05:38 PM
IROCNParts's Avatar
they are good, had to put an extra layer of silicone so that they wouldnt leak... It came with wiring adapter etc.. if you want some I have a hookup, $100 US for 2 with bulbs + wiring.
Old Aug 21, 2002 | 07:23 PM
CrazyHawaiian's Avatar
Car: too many ...
Go with PIAA's!!!
I did a small review of the H4 conversion versus a true H.I.D. conversion in the Electronics Forums, if you want to check it out. But anyway, if you want a set of driving lights (fog lights) to match those new headlamps, I would recommend PIAA lights. You can start your search here. I know alot of people will recommend that you just put new bulbs in your stock foglights, but that will never make as much light as the PIAA lights primarily because of the reflective properties of the insides of the PIAA's versus the Stocks. I bought a set of PIAA 1000X Platinum driving lights for my 92 B4C for $100. I will be installing them as soon as I move the Z-28 Grill Insert from my 90 to the 92. You can check out the specs on the 1000X Platinum's here. I think they are an excellent choice for daily driving, and they will match the brightness of the headlamps you installed. Here's a pic:
And here's another pic that will show you how the brightness levels differ between lamps ... notice how the PIAA lamps are right below true H.I.D. setups and above conventional halogen lamp setups ...
Old Aug 21, 2002 | 08:27 PM
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
Where can I get the stock fog light mounting hardware (and lamps)
Derick15
Sep 17, 2016 05:28 PM
86IROC112
Sep 7, 2015 01:37 PM
TheExaminer
Aug 26, 2015 04:59 PM
johanlindgren
Aug 16, 2015 12:16 AM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
