Wheel spacers?
Old Aug 22, 2002 | 11:08 PM
chevys's Avatar
Wheel spacers?
I have just purchased a set of Iroc wheels (see picture for the type), for my 88 Iroc with front and rear disc brakes.
I was wondering if I need spacers?
I noticed in the parts manual that they show a spacer.
Old Aug 23, 2002 | 06:44 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The spacers were stock on my IROC.
JamesC
Old Aug 23, 2002 | 06:49 AM
82camaro's Avatar
Car: 82 camaro SC
Some came with them and some didn't, depending on year and model etc... No you don't 'need' them. They are only 1/8 inch.
Old Aug 23, 2002 | 08:20 AM
Anth's Iroc's Avatar
Car: 87 IROC-Z
Engine: =350 sbc
Transmission: TH350
Why did GM put them on the cars?
Old Aug 23, 2002 | 10:13 PM
TheWraith's Avatar
Car: 1987 Camaro IROC Z28
Engine: 355
Transmission: 1994 T56
Axle/Gears: BW 3.27 (stock)
they went on cars with 16" wheels and rear drum brakes.
If you have drum brakes, it's probably not a bad idea to get them.
Old Aug 24, 2002 | 07:34 AM
JamesC's Avatar
According to Chilton's, TheWraith is correct. However, many cars--including my IROC which came with rear discs--had the spacers as well. The General strikes again.
JamesC
Old Aug 24, 2002 | 11:06 AM
82camaro's Avatar
Car: 82 camaro SC
What cars got them and what ones didn't varies alot. I'm running drums with 87 Iroc wheels without the spacers and I can't see any reason to get spacers--I don't want them to stick out any farther.
Old Aug 24, 2002 | 11:13 AM
Z28DJP1987's Avatar
If you are not the original owner, the wheel spacers were probably
lost or misplaced over the years. I would get them if youi are using 16" wheels and iron drum brakes.
Old Aug 24, 2002 | 11:25 PM
devianb's Avatar
If the IROC rear wheels have the 16mm offset, you will probably need the spacer if you have drums. I still can't figure out why some Fbodies have the seperate offset wheels. I know for a fact that all Trans Ams, base Firebirds, and Formulas have equal offset wheels, but the GTA doesn't.
Old Aug 25, 2002 | 12:29 AM
devianb's Avatar
correction: Formulas have 0 offset front/16mm offset rear combo with the 16" wheels.
Old Jan 20, 2004 | 12:56 PM
Bulldog92's Avatar
Car: '92 Camaro RS
Engine: 350 H.O.
Axle/Gears: 3.73 posi
This is an extremely old thread, but it was the only one I found that covered the factory GM wheel spacer issue. My '92 RS w/factory 16x8 aluminum wheels had this same spacer on the rear. I have since upgraded to 17x9.5 ROH ZS wheels, but now I really need a spacer on the front (not just the rear) because my tie rod end is too close to the inside edge of the rim. I currently have a pair of Mr. Gasket 7/32" (0.219") spacers on the front (thinnest I could find @ summit racing), but I KNOW that is way too thick. I don't see how I could be getting proper thread engagement, so I was wondering if any of you have a pair of factory GM .125" spacers laying around that you'd like to donate to a good cause...any takers?
I thought about just moving the rear spacers to the front, but then the front wheels would stick out further than the rear...
JB82Z-28
Exterior Parts Wanted
Oct 6, 2015 09:05 AM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
Fionnla
Wheels and Tires
Sep 11, 2015 11:07 PM
punkmaster98
Sep 8, 2015 09:45 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
