For "MettalliCamaro", I found it...
Old Sep 17, 2002 | 11:44 PM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
...Okay it is several months later but here they are. They Hood Blisters you asked me about for RS(flat hoods) or IROC's(different for each car) can be found at www.eastcoastcustoms.com for $99.00. Sorry it took so long but the papers were buried in my junky office.
Old Sep 18, 2002 | 09:32 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
Alright, I'll check it out. Thanks man.
Old Sep 18, 2002 | 10:30 PM
91Zman's Avatar
Car: 1991 Z28
Transmission: 4L60 automatic
Those look like the same thing but they are not,they're too short.
Old Sep 19, 2002 | 07:17 AM
Axle/Gears: Posi
91zman, Are you saying they are shorter than the factory ones or the RS ones are shorter than the IROC ones?
Did you purchase from them before?
Old Sep 19, 2002 | 09:28 AM
91Zman's Avatar
Car: 1991 Z28
I didn't purchase anything from them.You can tell from the pictures of the blue and the green ones that they aren't like the factory ones that are on my car.Yes they are way shorter and not as wide as the factory ones are.Also the edges on those seem to be the same thickness all of the way around.The edges seem flat,straight up were as the factory ones edges are slanted and thin.The thickest part is were that black insert is. Also did you notice that those aftermarket ones are for trucks? they are going to be shorter because of a truck's short hood.
Old Sep 19, 2002 | 09:34 AM
91Zman's Avatar
Car: 1991 Z28
Old Sep 19, 2002 | 09:42 AM
91Zman's Avatar
Car: 1991 Z28
Old Sep 19, 2002 | 02:45 PM
Y2KFirehawk's Avatar
Car: 00 T/A Firehawk
Engine: 346ci LS1
Transmission: MN6
Axle/Gears: 3.42 LSD
Here are the actual hood blisters mounted onto a flat RS hood...
Old Sep 19, 2002 | 02:55 PM
91Zman's Avatar
Car: 1991 Z28
WWasem
Are there any gaps between the blisters and the flat hood?Looks like there are some small gaps.Also did they bolt on nicely?
Old Sep 19, 2002 | 03:27 PM
Car: 1989 IROC-Z
Engine: 383 stroker
Yeah they don't look like they are exactly like the ones from the factory. I'll keep lookin.
Old Sep 19, 2002 | 03:59 PM
Engine: 346ci LS1
Transmission: MN6
Originally posted by 91Zman
WWasem
Are there any gaps between the blisters and the flat hood?Did they bolt on nicely?
No, there are no gaps, it's the shadow from the poor lighting. And they are the factory ones. I purchased them from Year One and they came in the GM boxes.
Old Sep 19, 2002 | 04:03 PM
91Zman's Avatar
Car: 1991 Z28
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
Abubaca
Nov 5, 2016 12:22 PM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
WickedBowtie
Sep 11, 2015 11:24 PM
rudolphschenker
Sep 4, 2015 02:41 AM
